Hi.
So I got the Mach X02 breakout board, and I am trying to get an serial com on it to work.
I've done stuff with Xilinx CPLD-s in the past with vhdl, but never something big enough that could support a proper included module.
I was looking for uart sourced on the web, but I couldn't not find any that was properly documented.
Later i found one that describes the MC6850 ACIA, which I actually used once, and it is simple to interface.
http://opencores.org/websvn,filedetails?repname=System09&path=%2FSystem09%2Ftrunk%2Frtl%2FVHDL%2FACIA_6850.vhdBut whatever I try, I just can't interface with it from the main vhdl source.
How do I port map the acia to my main design properly if I have a data, clock, and rx signal?
Edit: My main issue seems to be syntax, I tried looking into tutorials and examples, but I just can't get it right.
