I am looking for a nano with a real ftdi chip.
You might have to build one.
It's not clear that even the original Gravitech Nanos had "real" FTDIs. :-(
I suppose you can look at it as "at least it is an FTDI
compatable chip" as oppose to a CH340.
The CH340 works okay too but you do have to load another driver. For WinXP, the CH340 cannot distinguish one from another whereas, each of my FT232RL device has an unique ID on the FTDI bus. (I have four FT232RL device only, they each have a different ID so I am assuming it is by design rather than luck of the draw for my four FT232RL.)
So, with my FT232RL based stuff, I can RegEDIT the registry for that ID so my "Arduino" (ATMEGA+FT232RL made to look like an UNO) for temperature log will always use com3, my INA219 volt/amp "Arduino" always use com5, my FTDI RS232 to USB gets com2, so on. Regardless of order of plug in, my assigned com port for that FT232RL is always the same matching my corresponding PC data collection program specific to that application. The edit is cumbersome since RegEDITing those entry cannot occur while Windows is running. But once done, WinXP knows which of the four FT232RL I plug in and assign the "right" com correspondingly.
With my four CH340 based Nano, there is no unique ID associated with it. I have 4 so they are com9, 10, 11, 12. The first one plug in is always com9, regardless or which one of the four Nano I am plugging in. So I have to juggle the com port either on my PC program or juggle the port assignment in the device manager.
Apart from that, the CH340g Nano works rather well.
