Author Topic: EUSART  (Read 1104 times)
Offline ribnarkTopic starter
  • Country: in
EUSART
« on: December 14, 2016, 12:33:07 pm »
I am working on a project which requires to setup Asynchronous EUSART communication (Full Duplex) between two micro-controllers (Both PIC16F886). Everything works fine until I  unplug the cable connecting both EUSARTs and then re-plug it. After re-plugging nothing works till I reset anyone of the two micro-controllers. please help me to overcome this issue.
Thanks
Offline Wilksey
Re: EUSART
« Reply #1 on: December 14, 2016, 01:16:49 pm »
Without posting any code or schematics it's hard to determine!
However, are you checking for overflow and framing errors in your UART code?  When unplugging and replugging serial it can cause spurious data on the line.
I assume (hope) you are using a buffer and/or state machine for your comms?
