I have put a gentoo-x86/32bit stage4 inside a virtual machine
(virtual box) and it's running kernel version 2.6.39
I have added CIFS support in the kernel setup
and emerged mount-cifs utilities (mount.cifs)
then I have
enabled "sharing folder" (D:\idp.do) in WindowsXp machine
and filled the following in /etc/fstab
//192.168.1.12/idp.do/ /idp.do cifs auto,guest,users,rw,iocharset=utf8,file_mode=0777,dir_mode=0777,credentials=/etc/cifspasswd 0 0
(/etc/cifspasswd is properly set with my Xp password)
exp sim # mount /idp.do
apparently it works, I can access files in the shared XP folder through linux
but ...
exp # cd sim
exp sim # make
compiling pkg_SPB ... Makefile:13: recipe for target 'work/pkg_SPB.o' failed
make: *** [work/pkg_SPB.o] Error 2
exp sim # cd ..
exp sim # cp -r sim /root
exp sim # cd /root/sim
exp sim # make
compiling pkg_SPB ... done
in the first case, compiling files accessed through SAMBA does not work
while compiling the same files accessed through native-ext3 does work
what's wrong? any idea ?
