Have anyone programmed the STM32L432KC nucleo? I'm having hard time trying to simply turn a led on. I'm using CubeMx with Hal Library. I've set the pin as output, and used the following line: HAL_GPIO_WritePin(GPIOB, GPIO_PIN_7, GPIO_PIN_SET);
I had enabled an analog input for ADC. If I disable the ADC, the controller works fine, but if it is enabled, I can't do anything with my micro, it inhibits itself.
