Hi boys and girls !
I have a problem with the new ATmega328P
B and, after reading all the datasheet several times, I kindly request your help !
I am using both PWM outputs from the Timer 4 (on PD1 and PD2).
I am also using the UART0 to receive DMX data (receive only on PD0, no TX0 enabled,
so PD1 should be left free for OC4A).
Here is the issue :When I initialize the Timer 4 only,
both the PWM outputs are OK on PD1 and PD2.
(I figured that I need to write PD2 High in order to disable the Modulator and enable ouput OC4B, no problem here)
But when I initialize the Timer4
and I enable the UART0 receiver (RXEN0 only), then PD1 (OC4A) is stuck low.
Does anyone knows why PD1 (OC4A) is held low when RXEN0=1 (TXEN0 is still 0) ?
Thanks everyone !
Here is the initialisation code (stripped to the essential)
#define TOP_PWM 26666 //16MHz / 26666 = 600Hz
int main(void)
// I/O
DDRD = _BV(PD1) | _BV(PD2) ; // PWM ouputs
PORTD = _BV(PD2) ; // (+PD2 to disable Modulator (OCM)
// INIT UART (RX DMX)
//- baud rate = 250000 bps
UBRR0H = 0x00;
UBRR0L = 0x07;
UCSR0A = _BV(U2X0);
UCSR0B = _BV(RXEN0) | _BV(UCSZ02);
UCSR0C = _BV(UCSZ01) | _BV(UCSZ00);
UCSR0B |= _BV(RXCIE0);
// INIT TIMER4 / PWM (OCR4A/B)
TCNT4 = TOP_PWM;
TCCR4A = _BV(COM1A1) | _BV(COM4A0) | _BV(COM4B1) | _BV(COM4B0) | _BV(WGM41); // Fast PWM (mode 14)
TCCR4B = _BV(WGM42) | _BV(WGM43) | _BV(CS40);
ICR4=TOP_PWM; // TOP = 26666 (16Mhz/26666 = 600Hz)
OCR4A = TOP_PWM/2; //50% PWM for testing
OCR4B = TOP_PWM/2; //50% PWM for testing
while(1);
Here is the datasheet :
http://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-42397-8-bit-AVR-Microcontroller-ATmega328PB_Datasheet.pdf
