Author Topic: Lattice Diamond program FTDI issue  (Read 4222 times)
Offline peepo
« on: December 30, 2015, 03:32:22 am »
Help needed using Lattice Diamond 3.6.0.83.4 with MachXO3 Starter Kit on Ubuntu 14.04
Diamond is installed and runs, but does not program:
ERROR - Failed to Open FTDI USB port. Make sure to select the right cable type.
$ sudo udevadm test /dev/bus/usb/003/007
unable to open device '/sys/dev/bus/usb/003/007'
$ lsusb
Bus 003 Device 007: ID 0403:6010 Future Technology Devices International, Ltd FT2232C Dual USB-UART/FIFO IC
udev rules re: ftdi_sio added and restarted
Detect Cable:
INFO - No Lattice HW-DLN-3C (parallel) cable detected.
INFO - No Lattice HW-USBN-2A cable detected.
INFO - Board with FTDI USB Host Chip detected.
INFO - Multiple cables were detected.
Program:
Starting: "pgr_program run"
INFO - Check configuration setup: Start.
INFO - JTAG Chain Verification. No Errors.
INFO - Check configuration setup: Successful.
INFO - Device1 LCMXO3LF-6900C: LCMXO3LF-6900C: Verify ID
INFO - Operation Done. No errors.
INFO - Device1 LCMXO3LF-6900C: SPI-S25FL204K: SPI Flash Background Erase,Program,Verify
Initializing...
IDCode Checking...
ERROR - Verification Error...when Processing function: 'CHECK_ID'
ERROR - Operation: unsuccessful.
ERROR: pgr_program failed.
ERROR - Programming failed.
HW-USBN-2B (FTDI) is now pre-selected
Offline ale500
Re: Lattice Diamond program FTDI issue
« Reply #1 on: January 01, 2016, 05:56:29 pm »
Offline peepo
« Reply #2 on: January 01, 2016, 07:59:08 pm »
yes I read that thread ,
and left a reply asking  followers to reply to this thread.
Offline ale500
« Reply #3 on: January 02, 2016, 01:39:58 am »
That I read, but how about your usb configuration ? which ftdi module is being loaded ? (The usb issues are also present with altera's ByteBlaster as as usual Ubuntu is not officially supported but you can find how to do the usb configuration. I used to try this in CentOS having Diamond doing almost one try and then having to reboot to be able to try to program again, I didn't know at the time that ftdi_sio trick. That's why I suggested it.
Offline peepo
« Reply #4 on: January 02, 2016, 03:31:49 am »
okay thanks,
please list the tests you would like me to make,
ie to define and confirm why programming is broken.
brief notes:
Diamond 'Detect Cable'  is not showing USB2 option, though HW-USBN-2B (FTDI) is showing
I have set up udev rules and removed  ftdi_sio
I also made link to Diamond libftd2xx.so
