Author Topic: Li-ion battery selection  (Read 1397 times)
Offline ZeroResistanceTopic starter
« on: May 06, 2017, 03:37:57 am »
I am looking at Li-ion battery chemistries that would be suitable for inductive / motor loads. Basically my loads are bldc motors and the total wattage would be around 30 watts.
From http://batteryuniversity.com/learn/article/types_of_lithium_ion I see that NMC battery seems to be well suited for this is has good energy density, specific power, safety cost performance and lifetime.
The Lithium Iron Phosphate(LiFePO4) battery also looks interesting although its energy density is low compared to the other Li-ion chemistries but it is highly safe.
A search on amazon revealed that Panasonic is a reputed and reliable source of these batteries and they generally go in the 18650 form factor however the battery chemistry is stated as NCR, any idea how NCR compares to the NMC battery?
I'm open for Any other suggestions for battery chemistry to power the loads I stated earlier.
« Last Edit: May 06, 2017, 03:41:16 am by ZeroResistance »
Re: Li-ion battery selection
« Reply #1 on: May 06, 2017, 04:49:53 pm »
I want to delete this message because I want to post it in the right section but when I try to delete the first post it says
An Error Has Occurred!
You cannot delete your own topics in this board. Check to make sure this topic wasn't just moved to another board.
