Does this mean that when you use a development board from TI like this one: MSP-EXP432P401R
there are no size limits? ie the size limit applies only to boards the user makes?
There's another thread in here where they have linked a bunch of current deals from TI where you can buy an eval board and get a free nodelocked license.
If you buy the current deal where the MSP-EXP432P401R board comes with a full node locked license, then yes you'll have the full license. AFAIK, if you don't have the full license you just use CCS in demo mode (30 day full power) and then code limited.
That said - if you are happy to use GCC for compiling to MSP432, I think the code limit doesn't apply? AFAIK it's just for the TI MSP432 compiler... (I THINK. It's all a bit complex given the different processors and toolchains supported by CCS)
codesize limitation of 16kB
I have no feeling what this means. About how many lines of codes would this be? What kind of projects would be over 16k ?
thanks
16k will let you do some simple things and have some fun trying stuff out, but once you want to make something a bit complex and add in some large libraries (ethernet stack, maybe?) for supporting advanced features you'll have a problem. At the end of the day 16k is a very small program size for a cortex M4. I'm not sure it's possible to buy any cortex M4 from any vendor with flash that small.
