so, I happen to have realized a made in home linux SBC, and I'd like to test if the ram is OK since I have manually soldered it on the PCB.
do you know, guys, a method to check how good it is?
I could implement a few lines of C (1), but before reinventing the wheel I know I'd better ask, so here I am
(1) e.g. with a big malloc, and then doing pattern-check (address in address) inside the slice
may be a good idea?
