Electronics => Microcontrollers & FPGAs => Topic started by: legacy on July 05, 2016, 01:36:37 am
Title: looking for a tiny LCD
Post by: legacy on July 05, 2016, 01:36:37 am
constraints:
acceptable features:
I'd like to deal with a pure pixel-driven lcd
say 96x64..128x64 pixel is ok
SPI, or parallel interface (8-bit 6800-type parallel interface? z80-type? they are both ok)
passive LCD please (it needs to be power supplied by tiny battery)
backlight-option is not requested
3.3V or 5V
hobby purpose -> no production quality requested, large availability is not requested
do you have any tips for me?
I am going to design a very tiny portable engine  :D
Title: Re: looking for a tiny LCD
Post by: ebclr on July 05, 2016, 01:42:17 am
Chose the one you liked
https://world.taobao.com/search/search.htm?_ksTS=1467646625784_330&spm=a21bp.7806943.20151106.1&_input_charset=utf-8&navigator=all&json=on&q=12864&callback=__jsonp_cb&cna=ShKvDz0uo28CAbrLBSzQ%2FPF5&abtest=_AB-LR517-LR854-LR895-PR517-PR854-PV895_2462
Post by: legacy on July 05, 2016, 01:43:37 am
is it possible to purchase them line on ebay?
I live in Europe/Italy (hope the shipping is not a problem)
Post by: Signal32 on July 05, 2016, 01:47:26 am
The only thing that I know of that comes close to your requirements is the Transistor tester LCD, but the view area is bit smaller than what you need:
View Area : 55x30
Size: 65mm x 40mm
5mW Power
http://www.aliexpress.com/item/-/32294365696.html (http://www.aliexpress.com/item/-/32294365696.html)
http://www.aliexpress.com/item/-/32294365390.html (http://www.aliexpress.com/item/-/32294365390.html)
Post by: legacy on July 05, 2016, 01:51:02 am
mmm, most of those LCDs seem equal to LCDs offered by Adafruit and seedstudio
definitively too big or too small, for my application
also, the thickness has a constraint: no more than 4mm
but this (https://world.taobao.com/item/520410923392.htm?spm=a312a.7728556.2015080705.16.07wRwP&id=520410923392&scm=1007.12006.12548.i527881874905&pvid=5a11460a-059b-451c-982f-47a26fd35ce5) LCD is interesting, it's 66x38mm, 192x96 pixel, very  thick  :D
Post by: legacy on July 05, 2016, 01:54:42 am
yes, it's not a piece of cake to find out the proper LCD, ironically LCDs with a built-in Toshiba T6K04 driver happen to be perfect for my needs, unfortunately they are a customization by TI  :palm: :palm: :palm:
Post by: Kilrah on July 05, 2016, 02:02:54 am
The thickness is obviously due to the backlight assembly that you can probably remove.
Post by: picandmix on July 05, 2016, 02:51:55 am
Have a look at this EU based range of lcds.
http://www.lcd-module.com/products/dog.html (http://www.lcd-module.com/products/dog.html)
Post by: MT on July 05, 2016, 08:56:26 am
TME have surprisingly large selection of LCD's, quite affordable to.
http://www.tme.eu/en/ (http://www.tme.eu/en/)
Post by: Buriedcode on July 05, 2016, 09:49:47 am
I have ordered from 'artronic' a few times via ebay.  Ended up using some of their displays in a batch of 10 units, never had any issues with quality.  Using both the transflective, and transmissive - the transflective one being the one you're after.
http://www.artronic.com.pl/o_produkcie.php?id=1143? (http://www.artronic.com.pl/o_produkcie.php?id=1143?)
Glass is ~3mm thick, pins are 0.1" grid, view area is 60x33, dimensions 48.5x68.  I cannot say much about their customer service, never had to deal with it, but at the time I was stunned by the price, about £6 a unit, and that included adding the backlight to the cost.
Post by: MarkF on July 05, 2016, 10:58:43 am
Not LCD, but the OLED displays from Adafruit are very nice wiith a SPI interface.  I have the 1.27" 128x96 pixel display and really like it.
The 1.27" 128x96 OLED (https://www.adafruit.com/products/1673) or the 1.5" 128x128 OLED (https://www.adafruit.com/products/1431).
I wrote my own library for them to reduce program memory, but the Adafruit is okay if you're not limited for memory.
Post by: amyk on July 05, 2016, 11:39:27 am
Those are ridiculously overpriced... as in 10x more. Even if you mount them on a PCB and add some extra sub-$1 components they should still be <$10. Look here for example:
http://www.buydisplay.com/default/oled-display (http://www.buydisplay.com/default/oled-display)
OP may also try looking around on that site, others here have reported good success buying from them.
Post by: MarkF on July 05, 2016, 01:23:33 pm
I agree for the RAW displays you linked.  But, that's not what you're paying for.  The Adafruit breakboards generate the proper voltages (from 5VDC) and level shifting of signal lines (for TTL signals) and a MicroSD slot for extra memory.  They are a little pricey; but they are plug and play.
Post by: ale500 on July 06, 2016, 03:31:25 pm
I second the ones from electronic assembly (lcd-module.com). The DOG serie. They are thin, have something in the size you want, and they work. There are datasheets. I use the 132x32 and 160x104 versions. They need a few capacitors and have serial interface. And backlight  options are available, but you may push the dept beyond your stated 4 mm.
Post by: legacy on July 06, 2016, 10:51:56 pm
maybe the above LCD is useful for another project I have in my to-do-list  :D
lcd
Post by: moreab on July 10, 2016, 07:16:19 pm
Use OLED display 128*64 with 0.96" dimension
Post by: mikerj on July 11, 2016, 01:22:48 am
OP requires very low power, powered from a small battery so OLED probably not a good choice.
Post by: 22swg on July 15, 2016, 05:41:46 pm
The Textstar cw-lcd-02 is serial 2x16  50x26x6mm  , not sure if still available  also found this https://www.coolcomponents.co.uk/grove-i2c-lcd-display-w-universal-grove-cable.html. (https://www.coolcomponents.co.uk/grove-i2c-lcd-display-w-universal-grove-cable.html.)
