Hi
I wan to ask if you have any experience with digital controlled SMPS and if you using any tools to do all the math around
I have following DC/DC setup: full bridge IGBT, have current transformer to measure primary current also have over current protection compactor, and at secondary side, voltage sense and current shunt to measure output
I need to be able to control output as constant voltage and also as constant current
I'm little lost where to begin with all that digital compensation networks, is here any easy tools to do it (just put ADC values in and get needed duty cycle)?
processor used is STM32F103
