Author Topic: Low cost single board computer board that can run Win7  (Read 6866 times)
Online JesterTopic starter
« on: March 29, 2017, 11:01:38 pm »
I'm working on a test fixture that requires a PC running Windows for the already created test software. In the past I have used Via Embedded, however that was about 3 years back and there is always a faster, better , cheaper version it seems.
 Low cost
 Board would have to be small in the ball park of 10cm x 10cm (or smaller)
 Minimum 2 USB ports, prefer 4
 VGA
 Run off a small HD or SSD card using Win7
Does anyone have any recomendations?
Offline senso
  • Country: pt
    • My AVR tutorials
Re: Low cost single board computer board that can run Win7
« Reply #1 on: March 30, 2017, 12:33:10 am »
How much of a low cost it needs to be?
http://www.lattepanda.com/
But you need an HDMI to VGA converter, installing Windows 7 might be possible:
https://www.sevenforums.com/installation-setup/405205-how-do-i-install-windows-7-lattepanda.html
If you can/want to go the Aliexpress route, there are hundreds of NUC like single board pc's already with case's, ranging from celerons to i7's(the U flavor, so always a dual core with at most hyper threading), price ranging from 80€ to 400€, if you find one and only need the board, talk to the seller, might get a better deal without the casing.
EDIT: The Celerons are quad cores, but lower frequencies.
« Last Edit: March 30, 2017, 12:35:02 am by senso »
Offline pieman103021
« Reply #2 on: March 30, 2017, 01:26:09 am »
I always used to just browse for mini-ITX form factor fanless motherboards to find inexpensive embeddable ones.
As far as I know they may still be among the least expensive despite the fact that there are NUCs and pico ITX and other small form factors out there, many of those are somewhat "niche" and therefore demand a price premium.
I'm going to agree with this, although it may be possible to get a NUC for a good price if you look enough. That being said, mini-itx and NUCs are nearly 20x20cm, so if you absolutely need to fit in 10x10 you might have to use pico-itx.
Exclamation Point!
