It is just an application specific field that is sent along with the ACK. This is just a way for the receiver to communicate some information to the sender in the acknowledgment frame itself, without sending another frame.
In this case this field is used to tell the device to not go to sleep right away, and wait for the additional commands from the gateway.
By default this field is just 1 byte, but you can extend it to be as big as you want.
The stack itself never looks at this field. It is passed directly from the application layer on one side to the application on the other side.
