Legacy: How do you program your boards? I have to support a design with the 68332, and intend to use the PEmicro Multilink programmer.
Currently, I am operating via an home-made ROM emulator USB-bulk driven. It emulates two ROMs in parallel, and it's fine for the EVS board which have EVEN and ODD ROMs on the 16bit bus of the CPU. But the built-in firmware on the EVS board is a "DBUG32", a monitor that is able to upload stuff in ram. It loads and decodes SREC-S19, but it doesn't understand the S0-header if it contains metadata. It's very raw and wild, but it allows you to see, modify, and fill the ram. This can be re-used to prepare a gdb-bridge. Modern GDB repositories don't support anything about that, and the support they had for some old board, has been recently removed from modern releases. Therefore, it's all up to you.
I haven't yet tried the
PEmicro BDM, it's too expensive and it doesn't come with what I want and need, hence I am using the DI-module on the EVS board that comes with a BDM-to-uart debugger, and an LPT cable with a BDM interface. Both of them are driven by a DOS application, the one for the LTP-BDM cable is only able to program the flash, it can't be used to debug. The one on the DI-module does full debugging.
Anyway, the FPGA-BDM adapter I am willing to build will not be a PE replacement for the business/hobby since I am not willing to support anything else except a gdb-bridge for a simplified gdb-server.
p.s.
I am willing to buy a
Lauterbach ICE-68330 unit. It's the best ever, and it's the only tool that supports the TPU debugging: this information is completely missing in every public Motorola documentation I have ever read, and probably it's confidential and classified. Hence, if I will get my hands on the ICE I will for sure need to spend a lot of time at reverse engineering it.
The TPU is a wonderful and useful coprocessor. A couple of Beckman's spectrometers are based on 332 and use the TPU for their tasks. My understanding of details is limited.
