Author Topic: Making an auto tune device with fpga.  (Read 2825 times)
Offline kmesneTopic starter
  • Country: tr
« on: March 11, 2019, 10:51:28 pm »
Hi i am 2nd year ee student and i need to make a Project for my digital logic with vhdl course. I need to do it with fgpa basys3 board.
I want to make an auto tune device. When someone speaks it should tune it to 7 different chords like ( A, B, C, D, E, F,G and those minors/majors) and outputs the edited voice
There is computer programs which does is like fl studio vs.
My english is not my native i hope that i could tell what i have in my mind.
I really appreciate your helps.
Thanks
Offline Jan Audio
Re: Making an auto tune device with fpga.
« Reply #1 on: March 12, 2019, 02:04:51 pm »
You mean a "vocoder", divide into building blocks first.
Make envelop follower, use mic as input.
Have your oscillators volume adjusted by that.
Then you have this :
Make more transformer voices by adjusting pitch also.
Sorry i dont know anything about FPGA.
Offline emece67
« Reply #2 on: March 12, 2019, 03:51:19 pm »
« Last Edit: August 19, 2022, 02:18:20 pm by emece67 »
Offline Jan Audio
« Reply #3 on: March 12, 2019, 04:12:02 pm »
It was based on resampling and used only 2 interleaved circular buffers and AM modulation to get rid of time stretching due to resampling.
Do you have more info on this ?
Online SiliconWizard
« Reply #4 on: March 12, 2019, 04:21:16 pm »
I really suggest learning about the necessary algorithms first (vocoder, pitch shifting, etc) and then implementing them on a computer (with whatever language/tool you're comfortable with - MatLab or similar would probably be the faster way). Probably first with floating point, then once you have something that's satisfying, re-implement that with fixed point for instance. That will be your preliminary work before going to digital design.
Do not dive right into the VHDL part. You'd waste a lot of time.
Offline emece67
« Reply #5 on: March 12, 2019, 10:28:02 pm »
« Last Edit: August 19, 2022, 02:18:34 pm by emece67 »
The following users thanked this post: mrflibble, hamster_nz, MT, Nitrousoxide, Jan Audio
Offline hamster_nz
« Reply #6 on: March 13, 2019, 12:32:35 am »
  • Write samples at a given sampling frequency onto a circular buffer.
  • Read samples from such circular buffer at a different sampling frequency. This will change the pitch maintaining harmony
  • The WR and RD pointers to the buffer will walk the buffer at different speeds (obviously), when they point to the same sample a glitch will be heard. This is because:
    • If the read pointer overtakes the write pointer, then it reads a sample it has read before, instead of a new, not yet available, sample
    • If the write pointer overtakes the read pointer, then the soon to be read sample is overwritten by a new one, as the buffer is overrun
  • In order to not hear such glitches you modulate the amplitude of the output samples. The amplitude varies linearly as a function of the distance between the 2 pointers. When they are coincident the modulation is 0. When they are n/2 samples apart (n being the buffer length) the modulation is 1. You do not hear the glitches because you decrease the volume to 0 when they occur
  • But you will now hear such periodic volume variations. To avoid them you use a pair of read pointers n/2 samples apart (n being the buffer length). When one gives 0 volume (and produces a not perceivable glitch) the other gives maximum volume and no glitch. The output of the circuit is the sum of the modulated samples from the 2 RD pointers. As the modulation varies linearly and both channels are interleaved the overall amplitude is constant over time and no modulation is heard
  • You can get better results with more read pointers (say 8 pointers n/8 samples apart).
As I remembered this I noticed that you do not need 2 buffers, but only one with 2 read pointers. It seems even simpler than I remembered earlier.
The obvious drawback is that the input and output sampling frequencies are different.
Regards.
That is a really neat, simple design. I might give it a go!
Offline emece67
« Reply #7 on: March 13, 2019, 01:12:23 pm »
« Last Edit: August 19, 2022, 02:18:49 pm by emece67 »
Online BrianHG
« Reply #8 on: March 18, 2019, 11:04:33 pm »
Regards.
Déjà vu....
I've seen almost identical to this (inverted in function by keeping the read & write speeds are identical, but shifting the read position in such a loop) in an old Panasonic digital tapeless answering machine patent which allowed playback speed/tempo adjustments while maintaining a constant pitch.
Anyways, the king of auto-tune tools, Melodyne 4, (free functional demo) is located here: https://www.celemony.com/en/trial
Of just Youtube Melodyne 4 examples to see what it does...
Example: https://youtu.be/DiW6XVFeFgo?t=415
« Last Edit: March 18, 2019, 11:17:57 pm by BrianHG »
Offline mrflibble
« Reply #9 on: March 19, 2019, 04:31:03 pm »
In stereo where available. Nice design! Perfectly suited for a fun bit of experimentation, without breaking the project-time-budget bank. :D
