Hi!
i have build a step up converter using the connection in the datasheet.
The test with no load is able to produce a 10v input to 20v output, Which is great! And to check whether it is producing the desired output current of 150mA, abt 3w output, resistive loads were used.
However after testing under loaded condition by using two 270ohms rated 2w each connected in parallel, the load shorted.
i have also tried with two 100 ohms rated 10w which also shorted the load.
I tried with 4.7k resistance load and it does work but i am unable to tell whether the circuit can produce 150ma from this load.
May i know what other options can i try to test for the current?
The used componenents are
L: 180uh
Co: 220uF
rsc:0.5ohms
r1:10k r2 150k
Ct: 470pF
Diode: 1N5819
