Very strange, I have a board with 2 MCP39F521's for evaluation purpose.
None of them has something attached to OSCI and OSCO and they work anyway...
Here is the schematic for the Microchip demo board:
I gave up with this chip because I tried to use it a little out of his primary specs: DC application (the chip could deal with that) and high side current sensing via a current shunt monitor (mid biased to have bipolar current sensing with unipolar voltage ouput). The MCP39F521 is designed to be low-side direct current shunt sensing.
It is impossible to offset the current amplifier on the MCP39F to get signed value on the current. Believe me, I tried a bazillion values on a bunch of the config registers without success.
The datasheet is very poor as you said and it took me a lot of time to start with this chip. And, as always with i2c, I couldn't go back to the time I didn't own a logic analyzer with i2c interpreter.
My shortcut to start was to buy the demo board from Microchip, sniff the packets and code to mimic them on my microcontroller.
However, I guess it could be a nice if used properly chip because I found it quite precise and it processes a lot of data (active power, rms values, nice energy accumulators, ...) Theses values could be processed in software but it is quite time consumming to write these routines.
I'm glad I could help!
