Author Topic: FPGA in the Cloud (Amazon EC2)  (Read 3513 times)
Offline sleemanjTopic starter
  • Professional tightwad.
The following users thanked this post: paf
Offline Fsck
  • sleep deprived
Re: FPGA in the Cloud (Amazon EC2)
« Reply #1 on: December 01, 2016, 04:19:40 am »
"This is a one line proof...if we start sufficiently far to the left."
Offline hamster_nz
« Reply #2 on: December 01, 2016, 06:56:23 am »
And they are big ones too... the FPGAs have 6,000+ DSP blocks, and they offer option to have multiple FPGAs in the same instance.
Offline daqq
  • Country: sk
    • My site
« Reply #3 on: December 01, 2016, 02:24:30 pm »
They seem to fall out of the range of their free tools :(
Offline fki82
« Reply #4 on: December 04, 2016, 11:35:13 pm »
Wow, 1150k LE is a lot!
One of this FPGAs costs about 10000€!
Offline stfsux
« Reply #5 on: December 05, 2016, 12:08:48 pm »
Neat!
I would be interested in any feedback about this kind of services.
Offline CM800
« Reply #6 on: December 05, 2016, 11:20:22 pm »
Wow, I could imagine this having some huge potential for research companies and big number crunchers.
Offline alanambrose
« Reply #7 on: December 06, 2016, 06:02:32 pm »
Errr, what would you use that for? - clearly not for driving some local bus at high speed...
A.
“A foolish consistency is the hobgoblin of little minds"
Offline andersm
« Reply #8 on: December 06, 2016, 10:17:26 pm »
Problem-specific compute acceleration.
Offline hamster_nz
« Reply #9 on: December 07, 2016, 12:49:04 am »
A.
I was thinking that. You need to do very 'deep' processing of the limited data set.
Assuming you have 1GB/s of network bandwidth to get data in or out of the system. The large instances you have around 50,000 DSP blocks (able to run at 250MHz+?) - that gives tens of thousands of DSP operations per byte of data...
What you would use that ratio of bandwidth to compute for? No idea! (but then I lack vision :D )
I'm sure the Square Kilometer Array could give me a few hints...
