I'm trying to move variables from one module to another to make the code look nice. The code that I'm working is a little too complex so I copied a piece of simple code from online to test if this would work. Specifically, what I'm trying to achieve is to be able to input data from the top module into the lower modules and receive data back from the lower modules to the top module after some computation. However, when I do a simulation, it looks like the data doesn't move. Could some one please help me out?
My top module is this:
module file_top (
result , // Output of the adder
carry , // Carry output of adder
r1 , // first input
r2 , // second input
ci // carry input
input [3:0] r1 ;
input [3:0] r2 ;
input ci ;
output [3:0] result ;
output carry ;
wire [3:0] r1 ;
wire [3:0] r2 ;
wire ci ;
wire [3:0] result ;
wire carry ;
wire c1 ;
wire c2 ;
wire c3 ;
file_1 u0 (
.a (r1[0]) ,
.b (r2[0]) ,
.ci (ci) ,
.sum (result[0]) ,
.co (c1)
file_1 u1 (
.a (r1[1]) ,
.b (r2[1]) ,
.ci (c1) ,
.sum (result[1]) ,
.co (c2)
file_1 u2 (
.a (r1[2]) ,
.b (r2[2]) ,
.ci (c2) ,
.sum (result[2]) ,
.co (c3)
file_1 u3 (
.a (r1[3]) ,
.b (r2[3]) ,
.ci (c3) ,
.sum (result[3]) ,
.co (carry)
endmodule
My bottom module is:
module file_1(
a,
b,
ci,
sum,
co
input a,b,ci;
output sum,co;
wire a,b,c;
wire sum,co;
assign {co,sum} = a + b + ci;
endmodule
My testbench is:
module file_tb(
reg[3:0] r1,r2;
reg ci;
wire[3:0] result;
wire carry;
file_top inst1(
.result(result),
.carry(carry),
.r1(r1),
.r2(r2),
.ci(ci)
initial
begin
r1 = 4; r2 = 3;
#50
r1 = 2; r2 = 7;
#50
r1 = 3;r2 = 7;
end
endmodule
And the sim I get is attached here. ANy help would be very much appreciated.
