So i recently needed to use Visual Studio 2013 for a while , and while using it i grew very fond of the auto-code-sugest-complete thingy it has ( Code Assistance in MPLAB IDE ) .
This is a quick post describing how i " made " the same for MPLAB X IDE v3.45 .
Disclaimer : This i made for me , so its tailored for my needs . It's not perfect , or good for that matter . It uses Autohotkey to automatically press Ctrl + Space after every alphanumeric key input . But i do find it very useful , so if someone else finds it useful ... great , if not .... you can just close the tab
OK, so here is the Autohotkey code .
Loop, 26
Hotkey, % Chr(96 + A_index), AnyKey
Loop, 10
Hotkey, % A_Index - 1, AnyKey
AnyKey:
#IfWinActive ahk_class SunAwtFrame
Send %A_ThisHotkey%
Sleep, 50
Send ^{space}
SC027::
Send {;}
Send {esc}
How does it work :
The first part of the code makes all letters and numbers hotkeys .
Loop, 26
Loop, 10
Then when one of them is pressed
AnyKey:
it checks if its pressed inside the MPLAB text editor window ( so it does not work in other programs or windows )
quick note : if it doesn't work for you , use the Active Window Info to view the ahk_class , and replace it in the code .
And if its in the correct window it just resend what you pressed followed by Ctrl + Space .
Quick note : The delay , between the resending of the key and the Ctrl + Space , is to prevent the key you pressed to "bind " to Ctrl .
i.e if you type ANSELA fast enough , the last A binds to the Ctrl key , and you end up highlighting the whole document .
Send %A_ThisHotkey%
Sleep, 50
Send ^{space}
The last parts is for times when you assign values since it still suggest , so you need to press escape to close it and then press enter for a new line . Since that can be very annoying , every time you press the semi-colon it automatically presses escape for you , after sending said semi-colon .
SC027::
Send {;}
Send {esc}
And that's it , you just open the .ahk file when you launch your IDE .
I am sure it can be done better , but taking in consideration it took more time to write this post , than to make it , i am pleased with the result .
P.S One last thing to note is that most of the time there is no Code Documentation (
http://microchipdeveloper.com/mplabx:code-documentation ) , so the window its completely useless . unfortunately there is no way to disable it . Or i couldn't find it anyway .
