Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Microcontrollers
multiplexing five analog signals
« previous
next »
Print
Search
Pages:
Prev
1
2
All
Go Down
Author
Topic: multiplexing five analog signals (Read 4500 times)
dmills
Super Contributor
Country:
Re: multiplexing five analog signals
Reply #25 on:
June 22, 2018, 08:36:42 pm »
A 'Bus Switch", likely from Fairchild springs to mind for some reason, FST series probably, maybe a couple of FST3125s or suchlike?
Regards, Dan.
Logged
bullonwheels
Contributor
Country:
Reply #26 on:
June 25, 2018, 03:37:35 am »
I used the most used analog multiplexer CD4052. Best multiplexor for analog signals.
Logged
Geoff_S
Regular Contributor
Country:
Reply #27 on:
June 25, 2018, 03:40:21 am »
Would something like the Analog ADGS5414 work for you ?
http://www.analog.com/media/en/technical-documentation/data-sheets/ADGS5414.pdf
Logged
David Hess
Super Contributor
Country:
DavidH
Reply #28 on:
June 25, 2018, 12:05:48 pm »
The LT1398 and LT1399 were the parts I was thinking of and the datasheet shows an example of a 3 channel multiplexer made with an LT1399.
Logged
quickengprojects
Newbie
Country:
Reply #29 on:
June 26, 2018, 10:58:23 am »
As you are working with very low voltage, so it is preferred to pick the multiplexers with slightly high resistance that block too much current running from your circuit.
Logged
Print
Search
Pages:
Prev
1
2
All
Go Up
« previous
next »
Electronics
Microcontrollers
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
