The wattage is settable from the device and the resistance is adjustable by building a different coil.
When facing a difficult problem, it is advisable to simplify it to a point where you can articulate it to a lay person (me).
What you want, it seems to me, is a controller that will output a given (user configurable?) amount of power in to a load.
Depending on the nature of the load, and your goals, it can be very difficult to do; it can be also very simple to do.
For example, if the load is fixed, all you need is to output a fixed (user configurable) voltage onto that load. It can be done entirely in analog (a linear solution); or it can be done digitally (like a dc/dc converter).
If the load is reactive, it can be quite difficult.
The key is to dumb it down.
