Author Topic: Open source SPI Flash programmer  (Read 5939 times)
Offline ali_asadzadeh
  • Country: ir
    • ASiD Designer
« on: April 22, 2015, 04:18:55 pm »
I have stocked in here, I need a quick way of programming M25P16 device, do you know any open source parallel port SPI programmer software for it?
You can order parts from www.ASiDesigner.com
we are a wire-based company
Offline Scrts
  • Country: lt
Re: Open source SPI Flash programmer
« Reply #1 on: April 23, 2015, 06:20:16 pm »
I've got away using BusPirate and flashrom utility. It took like 5 minutes to rewrite 8Mb flash. I've heard people using BeagleBone with flashrom as standalone programmer and it's way much faster this way.
Offline Rasz
    • My random blog.
« Reply #2 on: April 23, 2015, 08:51:53 pm »
ponyprog? flashrom?
Offline poorchava
  • Troll Cave Electronics!
« Reply #3 on: April 23, 2015, 10:48:41 pm »
FT232, parallel bus driven by D2XX library. Software should be pretty simple to write by yourself.
  • Country: ir
    • ASiD Designer
« Reply #4 on: April 25, 2015, 03:09:51 pm »
Thanks for your suggestions, actually ponyprog does not support M25P series,and flashrom utility seems to be a Linux program, do we have a windows based software? because I'm a windows guy.
« Last Edit: April 25, 2015, 03:19:17 pm by ali_asadzadeh »
Offline Rasz
    • My random blog.
« Reply #5 on: April 25, 2015, 06:13:44 pm »
1 you can boot live distro from usb drive
2 there are dos ports of flashrom, here is one http://sat-prof.com.ua/showthread.php?t=4410
Offline Scrts
  • Country: lt
« Reply #6 on: April 26, 2015, 08:24:31 am »
And yet nobody did this apparently.
I've used it in windows.
  • Country: ir
    • ASiD Designer
« Reply #7 on: April 26, 2015, 08:10:02 pm »
Dear  Rasz,thanks for the info, the forum is in Russian and need's a registration for download, if you are a member would you please upload it some where, so I can download it.
Offline Rasz
    • My random blog.
« Reply #8 on: April 26, 2015, 08:13:20 pm »
niet
why dont you download from official repository? have you even checked http://flashrom.org/Downloads ?
  • Country: ir
    • ASiD Designer
« Reply #9 on: April 26, 2015, 10:17:16 pm »
Thanks, I have seen that page and I have downloaded version 9.8, it's a source code, also the windows section has a Snapshot downloads: http://ra.openbios.org/~idwer/flashrom/mingw  ,it's a command prompt bullisht! does this thing have a GUI? the Russian link that you provided seems to have a GUI
Offline Rasz
    • My random blog.
« Reply #10 on: April 26, 2015, 11:40:00 pm »
oh, Im sorry, I didnt realize I was helping an idiot  :palm:
Offline greminn
« Reply #11 on: June 26, 2015, 09:22:47 pm »
Dear Ali, I am currently looking for the windows snapshot v0.9.8. apparently the link is  not working anymore. can you please email me your download to my address: gremnn@aol.com? any help will be much appreciated! thanks david
Online amyk
« Reply #12 on: June 26, 2015, 11:06:43 pm »
Here is 9.1...
http://dangerousprototypes.com/forum/viewtopic.php?f=40&t=154&start=30
(WTF, Google? Why are the results for flashrom.exe so utterly useless? I find it hard to believe no one has posted a newer version of those binaries elsewhere on the Internet!)
Offline con-f-use
  • Country: at
« Reply #13 on: June 27, 2015, 03:05:01 am »
:palm:
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #14 on: June 27, 2015, 10:44:04 am »
Buy a TL886 programmer, it works pretty fine with flash memories, throw in a SOIC ZIF socket and you are set to rule the world.
Offline greminn
« Reply #15 on: June 28, 2015, 06:18:19 pm »
Here is 9.1...
Thanks,amyk. I could not find any flashrom.exe newer than v0.9.6  . the v0.9.1 is useless for me.  but anyway thank you.
Any people in the forum have a version v0.9.7 or v0.9.8 please let us share it.
regards
david
