Author Topic: Eagle goes rogue  (Read 17237 times)
Offline legacyTopic starter
Eagle goes rogue
« on: January 21, 2017, 01:51:59 pm »
Eagle goes rogue, so it is time to move to KiCAD, or gEDA  :popcorn:
« Last Edit: January 22, 2017, 10:39:20 am by legacy »
Offline jaromir
  • Country: sk
Re: PCB, does anyone used gEDA ?
« Reply #1 on: January 21, 2017, 02:55:55 pm »
There is subforum dealing with gEDA https://www.eevblog.com/forum/geda/
Offline donotdespisethesnake
  • Embedded stuff
« Reply #2 on: January 21, 2017, 07:11:09 pm »
Is Eagle no longer available as free/limited for non-commercial use?
As it happens, I am just now writing an Eagle-to-KiCad conversion tool. I wonder how long they will keep the file format open, could be a waste of time!
Bob
"All you said is just a bunch of opinions."
Eagle goes rogue
« Reply #3 on: January 22, 2017, 10:40:20 am »
Eagle is now property of Autodesk, and they changed their license into 500USD per year. So the license is no more a lifetime license, it has an expiration date, montly, yearly, you can choose, but no doubt it's more expensive.
No changes on the free-limited editions, but there are no more educational licenses.
awesome, is there a repository ?
  • Embedded stuff
Re: Eagle goes rogue
« Reply #4 on: January 22, 2017, 11:28:48 am »
It was intended for my own use, but I might publish it on github when it is slightly more usable.
Bob
Offline Karel
« Reply #5 on: January 22, 2017, 11:42:28 am »
Only the versions <= V7.70 which you can still download, install and use without the need to register:
ftp://ftp.cadsoft.de/eagle/program/
Offline iaeen
« Reply #6 on: January 22, 2017, 12:48:26 pm »
That's not quite true. There is still a free version, but it now requires an Autodesk account and it phones home to check up on you.
That's not a change to the capabilities of the free version, but it's worth being aware of.
Offline JacquesBBB
« Reply #7 on: January 22, 2017, 06:26:38 pm »
I wanted to try it, but
Offline Scrts
  • Country: lt
« Reply #8 on: January 22, 2017, 07:06:17 pm »
I'd be expecting this on Windows if it would throw an error saying: "You are using Windows 95, this software requires at least Windows XP". Well, Apple...
Offline iaeen
« Reply #9 on: January 22, 2017, 07:47:20 pm »
What do you expect Apple to do about it?
CadSoft decides which OS versions their software supports... not Apple.
Offline james_s
« Reply #10 on: January 22, 2017, 08:31:43 pm »
I evaluated Eagle some time back, must have been about 7 years ago and decided the free version was far too limited. I went with KiCad and have been using it ever since, seems like a no-brainer to me. I tried several other EDAs around the same time, played with OrCad at work, tried every hobbyist oriented package I could find as well as a couple other commercial ones. My conclusion was that they all suck, they all have quirks, they all have a learning curve, and once you learn your way around, most of them will do the job. Given the way Autodesk has behaved on this matter, I would not even consider Eagle.
Offline JPortici
« Reply #11 on: January 22, 2017, 08:33:43 pm »
unless it uses some of the newer OS feature it's easy to get around the version lock.
right click on the application, show additional content. open the .plist file and change the minimum OS version to whatever. save, apply command "touch" to the app and presto!
http://apple.stackexchange.com/questions/17396/forcing-getting-app-to-run-on-lower-mac-osx-version
The following users thanked this post: kripton2035, JacquesBBB
« Reply #12 on: January 22, 2017, 09:33:57 pm »
What do you think about OrCAD ?
Offline james_s
« Reply #13 on: January 22, 2017, 10:04:08 pm »
That was more than 12 years ago, it seemed complex and confusing at the time but I hadn't really learned any of them proficiently back then. Honestly I don't feel like I can have a useful opinion on OrCad at this point without seeing what a modern version has to offer. I've been using KiCad almost exclusively for a bit over 7 years now and done many dozens of boards in that time, I hardly notice the quirks anymore and have seen no reason to seriously pursue anything else. Perhaps if I were designing complex multilayer stuff like PC motherboards or RF products I would feel differently.
Offline JacquesBBB
« Reply #14 on: January 22, 2017, 11:10:06 pm »
Thanks for the tip. It  works !  (until I reach a problem)
I had to  register in autodesk, but this is minor.  Will see how it goes. Eagle is my CAD of choice.
Offline Scrts
  • Country: lt
« Reply #15 on: January 23, 2017, 01:36:06 am »
Is it easy to find libraries like it is for Eagle? Or you have to make every single component you need to use?
Offline Richard Crowley
  • KJ7YLK
« Reply #16 on: January 23, 2017, 02:19:36 am »
Re: OrCAD, No mention of price on their website, and "How to Buy" refers you to find a "channel partner" for a quote.  I learned decades ago, "If you have to ask the price, you can't afford it."
Offline james_s
« Reply #17 on: January 23, 2017, 04:27:17 am »
I haven't had any trouble finding libraries, although I only use them for common stuff like resistors, capacitors, IC form factors and whatnot. For anything else I normally just create my own parts, it's faster than looking for something that will work and I get precisely what I want rather than settling for close enough. That was something I learned early on when I was trying out different software, I'd find library parts that looked reasonable but weren't quite right or left something to be desired. They usually come in big collections so then my libraries get cluttered with hundreds of parts I never, ever use. It takes only a few minutes to create a new part and if you go off the datasheet or use a caliper to measure a part in hand, the layout for it will fit perfectly every time.
Offline timb
    • timb.us
Eagle goes rogue
« Reply #18 on: January 23, 2017, 05:17:40 am »
Exactly, never rely on third party parts libraries, you *will* get bitten. (Vendor provided libraries are generally OK, though I'd still verify each part with the datasheet's recommendations to make sure.
I don't know about Eagle or KidCad (see what I did there?), but in most sane EDA tools creating your own footprints is pretty easy.
If I create the footprint myself, which takes only a few minutes really, then I *know* it's right.
DipTrace (which is what I use) includes thousands of patterns as part of the core library and they all seem to be fine, though I still verify pad sizes and spacing for anything other than generic passives. (And if they need to be changed I can just copy the pattern in question from the core library to my user library and apply changes.
Offline james_s
« Reply #19 on: January 23, 2017, 05:40:22 am »
Creating parts in KiCad is pretty much the same as creating parts in any other EDA I've tried. You draw the schematic symbol in the library editor and you use the module editor to create and name the pads, draw the outline, etc. Eagle and KiCad are really very similar, all of the professional grade EDAs work very similarly, going from one to another is just a matter of learning the quirks.
Offline Wilksey
« Reply #20 on: January 23, 2017, 12:31:57 pm »
Farnell / E14 used to have parts on their website, not sure if they still do - can't say i've noticed the eagle part download button since they changed their website a few months back, I don't know if they still update it, but you can buy EAGLE still from Farnell / E14.
Anyone know for sure?
« Reply #21 on: January 23, 2017, 12:51:37 pm »
Here OrCAD v9 was 5200 Euro for a single node locked license.
A customer bought it.
« Reply #22 on: January 23, 2017, 12:58:49 pm »
Well, SAN MATEO, Calif. Intercept Technology Inc will give you a blast since their DrawingX, QCX and ReleaseX are priced at $25,000 each for a site license. All are supported on HP-UX/PA, Linux/x86, Solaris/Sparc and Windows/x86 platforms.
Located around San Jose, CA, New Cadence Allegro combines Best-of-Breed Design and Analysis Tools with a Co-Design Methodology Across All Three Design Domains IC, Package, and PCB. The Cadence Allegro platform supports Windows, Sun Solaris, HP-UX, IBM AIX, and Red Hat Linux platforms. Specific operating system support varies by product. U.S. pricing for a 1-year license starts at $54,000 for the Allegro Package Designer, $45,000 for the Allegro Package SI and $25,200 for the Allegro PCB SI.
In these cases, yes, just don't ask the price  ;D
Offline Scrts
  • Country: lt
« Reply #23 on: January 23, 2017, 02:31:17 pm »
It would be a pain to do components if you work with FPGAs. Do 484 pin component just eats time, especially when one pins has like 3 options. I guess there is also no way to import from other CADs?
« Reply #24 on: January 23, 2017, 03:22:20 pm »
well, any chance you happen have XC95108-7PC84C for EagleCAD? KiCAD?
Offline suicidaleggroll
« Reply #25 on: January 23, 2017, 04:19:11 pm »
I did that once, and then wrote a script to do it for me from then on (at least for Xilinx).  Now doing a 484 or 676 or whatever pin FPGA takes no more than 2-3 minutes with KiCAD with zero errors.  It helps that all of KiCAD's files are plain ASCII, so you can create or edit them however you like.
« Last Edit: January 23, 2017, 04:20:46 pm by suicidaleggroll »
Offline julianhigginson
« Reply #26 on: January 23, 2017, 09:41:01 pm »
I was just checking out the subscription page, and thought that $20/month would be handy if I ever wanted to work on eagle files. The big limitation is 2 signal layers, but if a power plane can be split to hold a couple of different power nets (can it??) that would be OK for a lot of projects.
And even the pro version is only $90/month. It'll mean that people like me can cheaply get their hands on Eagle to do a paid job if needed, without having to buy the full license, and just charge the rental of the license to the customer.. Compared to the old pricing model which I looked at ages ago and had about 10 different price points with different levels of features, I think this is an improvement.
The free version now seems able to be used professionally, but has the free version always been so terribly limited? - 2 schematic sheets?? yikes. I can see how makers will be annoyed if work done in their older free version of the software can no longer be used in the new free version..
I wonder what happens to everyone who owns a perpetual license for an older version?
« Reply #27 on: January 23, 2017, 09:47:35 pm »
well, if they really piss people off, or scare them away, I guess right now is the time where the conversion tool would be needed. On existing files.
Altium does an OK job of importing ASCII eagle projects too.... (though I have this niggling feeling there's also binary eagle format that eagle users can choose to save in?) I imported the EEZ-PSU project to have a look and it handled that mostly OK with a few spun around connectors. That could be an interesting project to test your converter on.. it has 3 different PCBs in one file, and a pile of schematic sheets in the one schematic file that relate to different boards in the PCB... if your converter can handle that it can handle anything! :-)
Offline westfw
« Reply #28 on: January 23, 2017, 10:32:37 pm »
A power plane would count as a separate layer in Eagle.   2 layers means two layer PCBs, not two signal layers in the CAD package.
The free version is NOT ALLOWED to be used professionally.  Non-commercial use only.
It used to be limited to one schematic sheet (of infinite size...)  This has never particularly struck me as a limiting restriction.
It used to be that $49 (then $69) would upgrade you from the free non-commercial version to the low-end commercial license (which had the same physical limitations.)  So if you designed an Arduino shield as a hobbyist and suddenly everyone wanted to buy it, you could shell out a bit of cash and be all legal and moral to sell PCBs on Tindie, or in your web store, or whatever.
« Reply #29 on: January 24, 2017, 01:41:52 am »
aaah - so by "signal layer" they mean *ANY* metal layer on the PCB? that's, well... the politest way i can describe that would be to call it "alternative terminology"
In that case, the $20/month version is pretty useless for anyone doing anything moderately interesting. Still. nice to know I can temporarily grab the full version for 90/month if I ever need it.
http://www.autodesk.com/products/eagle/free-download
"Download free version of EAGLE
PCB design software for students, makers, and professionals."
I haven't read terms past this download page, and I know what the rule used to be, but if you can't use it for professional work then it is NOT free software for professionals, and at very least they'll need to fix this page.
aaargh!!! the horror!
« Last Edit: January 24, 2017, 03:38:24 am by julianhigginson »
Offline Sal Ammoniac
« Reply #30 on: January 24, 2017, 01:57:53 am »
Typical marketing buzzword bullshit. I'm surprised they didn't use "synergy" as well.
Complexity is the number-one enemy of high-quality code.
Offline james_s
« Reply #31 on: January 24, 2017, 03:07:19 am »
Wow, that's right out of the corporate BS generator.
http://cbsg.sourceforge.net/cgi-bin/live
At a place I used to work, the CEO would send out emails now and then that sounded exactly like they were written by that. We would all look at each other and snicker whenever one came on.
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #32 on: January 24, 2017, 03:10:04 am »
The following users thanked this post: cgroen
Offline james_s
« Reply #33 on: January 24, 2017, 06:41:31 am »
Mission Statement Generator
Hah! Armed with this, I'm all set to become CEO of a fortune 500 company :)
« Reply #34 on: January 24, 2017, 01:05:58 pm »
I was looking for an EDA software for my HPUX v11.11 2xPA8900@1.1Ghz UNIX workstation.
Just because I am curious, but it's 10 orders over the definition of "expensive", so I am putting linux and KiCAD on it :D
Have you ever used Synergy ? If yes, where? UNIX? HP? IBM? SUN?
Offline AndyC_772
« Reply #35 on: January 24, 2017, 01:11:17 pm »
I use it every day professionally - Capture and PCB Designer, which is the entry level version of Allegro.
IIRC you can now rent this package for about £600/year here in the UK. I have a perpetual licence which was around £2000.
Offline Scrts
  • Country: lt
« Reply #36 on: January 24, 2017, 01:17:21 pm »
I have used Allegro HDL from Cadence for my work as automotive HW engineer. It's powerful tool with lots of custom integration we had, however I really liked Altium more.
Offline james_s
« Reply #37 on: January 25, 2017, 03:08:08 am »
£2000 for a perpetual license is a bargain compared to £600 a year. PCB technology has not changed much in a while, I'm not even sure what new features a CAD company could come up with to entice me to upgrade if I already had paid a bundle for a license. That's only going to get more true I suspect, which is why everyone is so keen on going to the subscription model. Thankfully with open source offerings getting better all the time, the ball is in our court.
Offline AndyC_772
« Reply #38 on: January 25, 2017, 07:54:51 am »
I felt much the same. The cost of rental is actually about the same as the (optional) annual maintenance and support fee for the perpetual licence, which I decided not to continue with this year as the updates coming out just weren't that useful to me. I have a tool now which works and which does everything I need.
There are a *lot* of additional features in the higher licence variants, though. If you ever find yourself thinking that an open-source tool might be somewhere near 'complete', just compare its feature set, performance and usability to something like Orcad PCB Designer Professional, which is about £4000 to buy.
Offline james_s
« Reply #39 on: January 25, 2017, 08:57:17 am »
Well the open source stuff doesn't yet match the high dollar pro stuff but it's getting closer all the time and for all but the most hard core hobbyists it's good enough. Big companies doing high end stuff will always be able to afford to pay for the top end software, that has always been out of the hobbyist reach anyway.
I've observed a trend with software in general, having been a computer enthusiast since the mid 80s. For a long time I eagerly anticipated the next version of practically anything. I drooled over the new features it would add, new capabilities it would give me, newer was always better. The same was true of hardware, a brand new top of the line machine was fast but never quite as fast as would have been nice. You never had enough RAM, hard drive was never big enough, monitor never had enough pixels or enough colors, there was *always* an upgrade on the horizon. Then sometime around a decade ago things started to plateau, productivity software pretty much had all the features people needed, for the first time ever available computing power really started to outstrip user needs. RAM got cheaper and cheaper, hard drives grew into hundreds of gigabytes and for the first time ever I started to have difficulty filling them up. I started encountering new versions of software that were actually *worse* than the versions they replaced. I got burned multiple times by this and upgrades went from something I eagerly anticipated to something I approached with caution or avoided entirely. New versions moved everything around, making arbitrary UI changes, adding useless features and/or taking away or breaking features I did use.  |O More recently almost everything has progressed to a rapid release cycle, QA has become largely a thing of the past, replaced with a ship it now, fix it later, fix it often mentality, a constant stream of updates that interrupt my work flow and break stuff that was working as often as they fix stuff that was broken.  :palm: Rather than a finished, tested product, software is in a perpetual beta, QA is passed on to the end user, and the product is in a constant state of flux like one of those project cars that is never finished, always being tinkered with and modified, :-/O always something half baked, zip-tied, dangling wires, accessories that aren't hooked up yet and sections of bare primer bodywork.
Well this has turned into more of a rant that I intended, I'll get off my soapbox now.  :horse:
The following users thanked this post: MagicSmoker, JoeO, Karel, rob.manderson
Offline Bruce Abbott
    • Bruce Abbott's R/C Models and Electronics
« Reply #40 on: January 26, 2017, 12:18:58 am »
There is a good reason for this. You see, the problem is that software doesn't wear out - and in an economy that relies on constant consumption of new products this is very bad news.
But don't worry, the fix is in. Modern software is designed to wear out after a fixed period, so you have to buy it again and again. This way the corporations can continue sucking at your wallet and get even richer. Ain't Capitalism wonderful?
Offline Karel
« Reply #41 on: January 26, 2017, 07:40:37 am »
Thanks to capitalism you are free to start to write and sell your own EDA software.
With communism everybody is obliged to use one and the same product owned by the state.
And the state will decide which features are good enough for you and which bugs will be solved.
Ain't that wonderfull?
Capitalism is far from perfect but all other solutions are worse. Read some history.
Look at which countries build fences to keep people out and which countries build fences to keep their people in.
The following users thanked this post: Richard Crowley
Offline CJay
« Reply #42 on: January 26, 2017, 08:15:06 am »
There's been mention on the Time Nuts mailing list of an email address where you can send your concerns about Eagle, apparently Autodesk seem to believe the subscription model is welcomed by customers.
Support.eagle@autodesk.com
(Sorry if this is a breach of some nettiquette rules but, screengrab of the relevant email body)
Offline james_s
« Reply #43 on: January 26, 2017, 08:51:47 am »
I'm not anti-capitalism, but like any system it does have flaws. It works both ways though, yes a company can try to charge whatever they want for something, but I can also decide whether or not I agree with the terms and I'm free to shop elsewhere. The more mature a software product gets, the less significant each iteration becomes so the easier it is for community developed open source software to catch up. At some point it might just be the case that software isn't worth as much as it used to be. There are only so many times one can reinvent the wheel, and since software never wears out you have to either keep finding new customers or keep convincing existing customers to buy new versions. I get that, but I'm not obligated to support a given company's business model.
« Last Edit: January 26, 2017, 04:48:22 pm by james_s »
Offline Karel
« Reply #44 on: January 26, 2017, 09:52:10 am »
To cut a long story short, the biggest problem with EDA software is vendor-lockin & non-standardized (and proprietary) file formats.
The only real solution for this is to make available and/or improve the already existent open-source EDA packages.
If enough companies start to donate money / programmers, the problem will be solved and we will reach something like Libreoffice which is,
at some points, maybe not as good as ms office but is still perfect for 95% of the users.
« Reply #45 on: January 26, 2017, 10:09:10 pm »
But why would they do that? Donating money and programmers just cuts into profits and kills their market. In a Capitalist economy, any company that gives their stuff away is cutting their own throat unless it's just a hook to get customers buying their other stuff, and/or an attempt to kill the competition so they can corner the market.
On the other side we have programmers spending a lot of time and effort to develop true open-source software simply because they think others might need it - with no expectation of any payback. That's not Capitalism, so what is it? Sound more like...
'a theory or system of social organization in which all property is owned by the community and each person contributes and receives according to their ability and needs.'
« Reply #46 on: January 26, 2017, 10:31:55 pm »
Eagle goes rogue, so it is time to move to KiCAD...
I tried KiCAD a while back and hated it. Perhaps it's improved now? Let's see...
Oh yes, now they have a wonderful 'push and shove' router! Just one problem - for some peculiar reason it only works in OpenGL. Why would that be a problem for me? The graphic driver in my computer has OpenGL v2.0, but KiCAD needs v2.1!!! Why???
And the user interface still sucks...
Offline Karel
« Reply #47 on: January 26, 2017, 10:43:06 pm »
So, why are the biggest contributors to Linux big "capitalistic" companies?
Because they use Linux as a tool to run their business. And there's no reason why
electronic design companies can't do the same.
Offline james_s
« Reply #48 on: January 27, 2017, 12:13:14 am »
Beats me, but you could buy a nice new PC dedicated to running KiCad for the cost of renting Eagle for a year or two.
The interface kinda sucks, but the Eagle interface sucks too, it's just a matter of what you're used to. I used to use Eagle but I've been using KiCad for quite a few years now and it's fine. I tried every EDA I could get my hands on and came to the conclusion that they all suck, stick with any one of them and most will do the job.
« Reply #49 on: January 27, 2017, 12:24:10 am »
Well OpenGL  :palm: :palm: :palm: :palm:
Offline Bassman59
  • Yes, I do this for a living
« Reply #50 on: January 27, 2017, 05:06:47 pm »
Perhaps you can ask your graphics card vendor to update their drivers.
« Reply #51 on: January 28, 2017, 05:27:49 am »
Ask Dell? Yeah right.
Their website has a page with (presumably the latest) drivers for all their machines - only problem is it doesn't work for me. I can select the computer model, graphics card etc., but clicking the download button does nothing. At some point the frustration just isn't worth the effort...
Quote from: james_s
The interface kinda sucks, but the Eagle interface sucks too.
Sure, but KiCAD sucks more. Nevertheless I will learn how to use it, in case I need to make a large/multilayer board that the free version of Eagle can't do.
  • Embedded stuff
« Reply #52 on: January 28, 2017, 02:24:23 pm »
OpenGL 2.1 was released in 2006, 10 years is a pretty reasonable time to allow for adoption. It's not like you need last year's hardware.
Funny, I have just being getting to grips with Eagle in order to test my project converter. I find in Eagle I can't even select an object reliably, I often end up rotating some other object instead. It's been driving me nuts, do I really need to consult the manual just to figure out how to select an object? In comparison, KiCad's method is reliable and easy to use, so I in this case I would give the points to KiCad.
The judgement of "suckiness" seems pretty much to be what you are used to.
Bob
Offline Scrts
  • Country: lt
« Reply #53 on: January 28, 2017, 05:49:10 pm »
I always go to graphics card manufacturer website and get the latest drivers there. My HP laptop support page offers older drivers. When I updated graphics drivers from Intel, there was windows update offering me older drivers from Microsoft.
« Reply #54 on: January 29, 2017, 05:02:34 am »
ATI is apparently owned by AMD now and I can't find a driver for my card on their website. I have a newer PC that surely will work but I don't want to move it into the workshop, so at this point I am resigned to just running KiCAD in default graphic mode.
Now the newbie questions begin...
To drag an object in KiCad you hover over it and press 'G'. So I do this over a via and it pops up a menu with 4 options - the via itself and the 3 tracks connecting it to it.
Question 1: is there any way to make KiCad select the via automatically, or do I have to traverse the menu every time?
Question 2: If I have to select a track from the menu, how can I tell which one to select (apart from trying to figure it out from the descriptions)?
Question 3: If I select the via then it snaps to the visible grid when being moved, but if I select a track it snaps to a larger grid. Why does it do this?
Offline alex0801
« Reply #55 on: January 29, 2017, 09:12:53 am »
Time to finally switch to KiCAD....
Online wraper
  • Country: lv
« Reply #56 on: January 29, 2017, 11:48:24 am »
:-// Sorry, I don't buy it. On AMD website you can download even win98 drivers for Radeon 7000 series from 2001. what is GPU model?
« Reply #57 on: January 29, 2017, 12:12:08 pm »
Jesus, can't you buy a new laptop ?
« Reply #58 on: January 29, 2017, 09:26:58 pm »
Radeon X600 256MB Hypermemory. Please show me where to download the driver from AMD's website!
« Reply #59 on: January 29, 2017, 09:36:02 pm »
It's a tower not a laptop. I could buy a new graphics card for it I suppose, but if I have to buy new hardware just to run KiCad then that Eagle subscription starts to look a lot more attractive.
Anyway enough of that. Does anyone here actually use KiCad? Where can a newbie get good advice on how to operate it efficiently?
Offline Wilksey
« Reply #60 on: January 29, 2017, 11:16:22 pm »
Not when you can buy a new GPU for £50 as a one time purchase, and the EAGLE subscription costs £400 per year.  Use yer loaf!  ;D
Offline james_s
« Reply #61 on: January 29, 2017, 11:31:15 pm »
You could buy an entire brand new PC every single year for the cost of an Eagle subscription, only you don't have to, buy it once and you're good for another decade.
I've been using KiCad for about 8 years, I've done many dozens of boards including two commercial products with it. There's a KiCad forum right here on eevblog.
Offline Scrts
  • Country: lt
« Reply #62 on: January 30, 2017, 12:13:45 am »
Option 1:
http://support.amd.com/en-us/download/desktop/legacy?product=Legacy1&os=Windows%20Vista%20-%2032
Option 2:
Find Radeon custom drivers. For example there were Radeon Omega drivers. Tweaked stuff.
  • Embedded stuff
« Reply #63 on: January 30, 2017, 12:44:55 am »
You could also try https://forum.kicad.info/, there is a Yahoo group but I wouldn't recommend it.
Bob
Offline james_s
« Reply #64 on: January 30, 2017, 01:56:34 am »
Does anyone still use the yahoo group? I used to belong to a number of yahoo groups, they all became unusable after Yahoo revamped everything and they died out.
Online wraper
  • Country: lv
« Reply #65 on: January 30, 2017, 08:54:08 am »
Offline Bassman59
« Reply #66 on: January 30, 2017, 05:14:40 pm »
I was being facetious -- my Dell Studio XPS running Win7 kept exhorting me to UPGRADE TO WINDOWS 10 RIGHT NOW! during that free upgrade time last year. After being assured that I could revert back to Win7 (and ensuring my backups were up to date), I did so. And the machine booted into 640x480 VGA and the two displays were mirrored. Dell no longer supports the machine, and AMD doesn't support the graphics card. I reverted back.
As for why the CERN guys chose OpenGL 2.1 instead of 2.0? You'd have to ask them. There is always going to be pain at where you draw your development line.
« Reply #67 on: January 30, 2017, 09:24:48 pm »
Been there, done that. Clicking "display results" did nothing. But wait, perhaps there is a reason for that? Turned off hosts file and... bingo!
That's the good news, now for the bad. Installed driver from AMD. Now KiCAD switches to opengl and... promptly crashes!  >:(
Time for a system restore....
« Reply #68 on: January 30, 2017, 09:44:12 pm »
there's a KiCad forum right here on eevblog.
Thanks for that, checking it out now!
