Thanks for replies!
To be more detailed; I need cheap clock source for HART modem on 460.8kHz - but there is no requirement to be very accuracy on full temperature range, because I need HART only for for load some setting via HART after assembly and casted PCB.
Okay, I see that the idea with OSCTUNE is not feasible, so another possible option is by Ian.M, with CCP module (in combination with OSCTUN anyway, to get as close as possible wished frequency). Thank you for this suggestion.
The only problem here can be the power consumption in this way, but over the thumb I think it should be under the limitation.
Anyway, backup solution is the 1.8432MHz crystal, but this is not desired because of its size.
