Author Topic: PIC24F serial bootloader-P24QP "Run time error 53"  (Read 1032 times)
Offline muthukural001Topic starter
  • Country: in
« on: May 05, 2018, 03:41:34 pm »
Hello All,
I am developing UART bootloader for PIC24FJ128GB206. I loaded bootloader code using pickit3. Then, I used P24QP serial programmer software application to load Applicatio program. Doing this, I was able to detect my MCU device id. But, when I try to write Application hex, I am getting "Run time error '53 '" and "File not found".
I don't know where to debug. It would be greatful if anyone suggest.
Thanks,
Muthu
Online Howardlong
Re: PIC24F serial bootloader-P24QP "Run time error 53"
« Reply #1 on: May 05, 2018, 08:37:40 pm »
Hello All,
Thanks,
Muthu
53 sounds like a raw doserror at your PC, rather than a debugger/programmer error.
ERROR_BAD_NETPATH
53 (0x35)
The network path was not found.
