Author Topic: PIC32 now have a MMU...  (Read 7176 times)
Offline technixTopic starter
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« on: April 21, 2017, 04:33:44 am »
For example, PIC32MZ2048EFM144, have a MMU (and thus virtual memory system.) I smell mainline Linux - in fact, there is already PIC32MZ support in the latest mainline Linux.  :scared: Its memory map allows for 64MB of PSRAM and 64MB of Quad SPI NOR Flash. That is enough for a small-ish vanilla Linux 4.11 build (not the uClinux 2.6.x junk - the latest mainline kernel instead.) The built-in Flash have enough room for a full U-Boot installation too, and QSPI can XIP to conserve memory.
So what is this line of "microcontrollers" intended for again? I don't think that a normal microcontroller should have mainline, vanilla Linux in its sights. Or should us start calling it System-on-Chip instead?
  • Country: cn
    • My Untitled Blog
Re: PIC32 now have a MMU...
« Reply #1 on: April 21, 2017, 05:09:11 am »
USB HS, LCD Parallel Port, I2S -- it looks like a chip designed for HMI or other industrial LCD applications. Definitely not for consumer devices when running Linux -- PSRAM is expensive, DDR3 is cheap as dirt.
It don't have SDRAM controller yet - just PSRAM. If a future revision got a SDRAM controller this would really become a full consumer-ready Linux chip.
Offline krho
  • Country: si
« Reply #2 on: April 21, 2017, 05:27:55 am »
That's ultra expensive especially as you can get imx6UL which is 600MHz Cortex A7 with DDR&LCD&eMMC controllers  at <6€@1000pcs and iMX6ULL even cheaper ~4€@1000pcs.
Offline westfw
« Reply #3 on: April 21, 2017, 08:54:56 am »
Didn't even the MX PIC32s have enough "memory managment" (separate 0-based segments for User and System; perhaps inherent in the MIPS architecture) to support older sorts of unix?  One of the mid-sized chipKit boards had 2.10bsd running on it, I think.  (yeah, I think you have to actually swap, like in the good old days...)
Offline mrpackethead
  • D Size Cell
« Reply #4 on: April 21, 2017, 11:29:24 am »
$9.23 at 10k qty, doesn't seem to be consumer friendly. There are cheaper AllWinner chips with design documents available for free
If yoru buying 10k at that price, your paying way too much.  Have a talk to a MC sales team.    AT 9.23 you woudl be right they woudl be uncompetitive. Microchip is beomcing a force to reckon with..
Offline tszaboo
« Reply #5 on: April 21, 2017, 01:43:03 pm »
I've seen people run Linux on Spartan 3. Linux guys are not concerned with things like price or ease of use. Or any practical considerations.
Offline Scrts
  • Country: lt
« Reply #6 on: April 21, 2017, 03:09:18 pm »
Are those MTK, Rockchip and Allwinner processors fully documented and that documentation fully released to the public? Have you tried to set up low level DMA, SPI, I2C on them? If this is not available, then those processors are useless for DIYer.
Offline VEGETA
  • Country: jo
  • I am the cult of personality
    • Thundertronics
« Reply #7 on: April 21, 2017, 04:30:17 pm »
Perhaps they want to complete with Renesas RZ series in the future.
Offline Rasz
    • My random blog.
« Reply #8 on: April 21, 2017, 04:33:22 pm »
Its not about virtual memory for linux, but exceptions, all about making it more RTOS friendly. MMU lets you mark stack non exec, try to recover from RTOS processes writing into wrong space or stack growing over your data.
Datasheet for this part reads like its been designed for automotive use?
  • D Size Cell
« Reply #9 on: April 21, 2017, 06:38:45 pm »
datasheet links?
Offline thm_w
  • Non-expert
« Reply #10 on: April 21, 2017, 09:07:54 pm »
$9.23 at 10k qty, doesn't seem to be consumer friendly. There are cheaper AllWinner chips with design documents available for free form Linux sunxi website, and with some commitment to buy, there are other options such as Rockchip and MTK. Even for bigger brands like Freescale, they have cheaper chips with full Linux capability.
I'm currently working on a music player based on iMX6ULL, it costs less than $5 at mass quantity, and it runs at 528MHz with DDR3L support. It has LCD controller, full Yocto based Linux, dual USB controller and all sorts of standard ARM SoC peripherals (SPI, DMA, ETH, etc.).
I think the new PIC32 is designed for those who have existing PIC32 code and want to add LCD and Linux capability quickly to their expensive industrial products, or for those who want to use existing PIC32 library from Microchip to build an industrial gear as fast as possible, while not being sensitive to cost.
iMX6ULL is impressive but you can see the difference:
MCIMX6Y0CVM05AA vs. PIC32MZ2048EFM144
- bga only vs. TQFP only
- 128kB RAM vs. 512kB
- 96kB flash vs. 2MB
- 105 C vs 125 C
I think its quite reasonably priced given these specs. But yes clearly for a different market.
Offline Sal Ammoniac
« Reply #11 on: April 22, 2017, 12:03:50 am »
Does the PIC32MZ have a real MMU that can translate individual virtual pages of 512-4096 bytes into physical addresses, or does it just have a simple MMU like the ARM Cortex-M4 has, which can just set access protections on certain areas of memory?
As an aside, what's the attraction of running Linux on a part like this? Will you have enough resources left to do anything useful after cramming the OS onto the part? What's next, porting Linux to your smart toaster?
Complexity is the number-one enemy of high-quality code.
Offline TNorthover
« Reply #12 on: April 22, 2017, 02:34:25 am »
I think "MMU" is pretty much reserved for full address translation schemes. Certainly ARM refers to the Cortex-M scheme as an MPU, though that term looks like it might be vague enough to cover a lot of things if you believe wiki.
Offline tszaboo
« Reply #13 on: April 22, 2017, 08:21:54 am »
- 105 C vs 125 C
Irrelevant specs, you will never use in iMX witout external DDR memory and Flash.
Offline forrestc
« Reply #14 on: April 22, 2017, 09:10:20 am »
The PIC32MZ EF line apparently doesn't have enough resources to run Linux.    But there are lots of applications where linux doesn't make a lot of sense but you still need a beefy processor with connectivity.   I'm actually using the PIC32MZ EF in several projects.
When you look at the total system cost, the PIC32MZ EF isn't all that bad since you generally don't need any external memory.
There is a multi-die version of the PIC32MZ coming, the PIC32MZ DA.  It is apparently going to be able to run Linux, but based on the curriculum at the masters coming up in October, it sure looks like Microchip's path to Linux is going to be at least initially on the ARM-based SAM processors they acquired with atmel.
Offline thm_w
  • Non-expert
« Reply #15 on: April 24, 2017, 10:40:56 pm »
But its possible the PIC would be used without external flash or memory, no?
The point is its a different market, there is more on chip resources and the cost will be proportionally higher due to that.
1-2MB of flash on chip is not cheap, although I'm not sure if this is manufacturer set margin or actual cost of silicon. 2MB winbond flash is about 60c.
Offline Rasz
    • My random blog.
« Reply #16 on: April 25, 2017, 12:04:27 am »
flash itself is super cheap at those capacities (< tens of megabytes). Its flash and larger high speed logic on same wafer that makes it expensive. Same for large SRAM or DRAM on same die.
The problem as I understand(barely) lies in specific additional processes (high temp baking, polishing, deposition, masks) required by memory structures.
quick google throws up this book "Memories in Wireless Systems"
with a nice table listing additional manufacturing steps: https://books.google.pl/books?id=1tX44UwMoA4C&pg=PA13&lpg=PA13&dq=flash+memory+process+additional++manufacturing+special+steps&source=bl&ots=d79DEXKE1e&sig=ESK_cAeKn2bqDYy1pgPndjpwzes&hl=en&sa=X&ved=0ahUKEwi2sITJpb7TAhXmBZoKHfWJAigQ6AEISjAG#v=onepage&q=flash%20memory%20process%20additional%20%20manufacturing%20special%20steps&f=false
This is why we end up with cool stuff like this
https://zeptobars.com/en/read/GD32F103CBT6-mcm-serial-flash-Giga-Devices
when manufacturer is price conscious but still wants to deliver.
