Author Topic: STM8S Discovery board with bigger mcu.  (Read 2836 times)
Offline mrflibbleTopic starter
« on: February 14, 2013, 07:34:15 pm »
I thought I'd get me some STM8S-Discovery boards, wave the hot air wand a bit and swap out the installed mcu with a more capable one. Specifically, remove the STM8S105C6T6 and install a spiffy new STM8S207CBT6.
I went over the disco board user manual and the 2 mcu datasheets and can't think of any reason why this should not work. But maybe someone already went through this exact same process and knows of any gotchas...
Offline bingo600
Re: STM8S Discovery board with bigger mcu.
« Reply #1 on: February 14, 2013, 08:36:21 pm »
I only have 1 argument against the STM8 -
The C-Compiler is either crippleware or $$ware.
I have 4 STM8S that i bought just for the "snappable" Jtag/Programmer part (Use Versaloon firmware) , i have never even bothered to apply power to the STM8 part.
Get a STM32F4-Discovery if you need power or space
/Bingo
« Reply #2 on: February 14, 2013, 09:19:16 pm »
Do you mean to imply that documentation for STM8 is not as shit as for STM32? I'll just add "crap documentation" to that list shall I? ;-)
Heh, I already have a few of those and more on the way. :)
The STM8 is for a project where I basically need N times (DAC input + PWM output), where the PWM outputs preferably have to support center aligned mode and the cost per IO is as low as possible (you know, the usual). The STM32 certainly will have all the required capabilities but cost per IO pair (DAC input + PWM output) is quite a bit higher than for a STM8 solution.
It doesn't even have to be ST. I am perfectly fine with something MSP430-ish or NXP LPCxxx or AVR if it fits the bill. Hell, I might even consider Microchippie but it had better be a really good fit for the project. :P I went over all of that and STM8S2xx seems to be the best fit for the requirements of which the above is a very rough sketch. :p
« Reply #3 on: February 17, 2013, 05:22:03 pm »
Noone? Oh well, guess I'll find out soon enough.
