Author Topic: PICs for my PICKIT2  (Read 11701 times)
Online metrologistTopic starter
PICs for my PICKIT2
« on: June 28, 2016, 08:19:44 pm »
What are good chips to use with PICKIT2? Looking for a short list of the higher end chips and some with 10 bit ADC/DAC.
I bought the kit years ago, but just got caught up with Arduino, so looking to move from the 328p.
Offline dannyf
Re: PICs for my PICKIT2
« Reply #1 on: June 28, 2016, 08:44:59 pm »
Check out the supported device list and pick from that.
I would suggest that anything less than a pic24 is a big step back from your avr.
Offline Howardlong
« Reply #2 on: June 28, 2016, 08:51:00 pm »
There's a list of supported devices here http://ww1.microchip.com/downloads/en/DeviceDoc/PICkit%202%20Readme%20v2-61-00%20(a).txt
Anything released in about the last five years isn't on that list.
DAC will be the hard part.
dsPIC33FJxxGS parts look the most likely correlation wih this http://ww1.microchip.com/downloads/en/DeviceDoc/30010109B.pdf
Offline JPortici
« Reply #3 on: June 28, 2016, 08:51:40 pm »
pic16f1823/47, pic16f1936
many dspics, too
Offline Howardlong
« Reply #4 on: June 28, 2016, 08:58:17 pm »
many dspics, too
10 bit DAC though on PIC16 -and- supported by PICkit 2?
Also to the OP, check that the DAC is exposed to the pins if you need it (frequently they are only available internally for comparators). Even then, you may well need to buffer them.
Online MarkF
« Reply #5 on: June 28, 2016, 09:15:26 pm »
Here is the newest "Device File" I've been able to find.  It has been updated by PICkit2 users.
Offline JPortici
« Reply #6 on: June 28, 2016, 09:45:32 pm »
eh, the PK2 is old.
Rumors are that you can still add all the new 8 and 16 bit parts but i never investigated how.
the only 8 bit parts with 10 bit dac are the pic16f17xx but they are only supported by PICKIT3/ICD3
for 16 bit i suggest you cross reference the latest device list and the catalog. there are for sure some with 8 bit dac, not sure about 10,12,16
the pics i mentioned before would be my go-to if i was forced to use a pickit 2. also PIC16F15xx for a lower cost variant
Online MarkF
« Reply #7 on: June 28, 2016, 09:52:12 pm »
You can add new parts to the PICkit2 with the "PICkit2 Device File Editor".  I can't remember where I got it.  So, I attached the version I downloaded.
Offline ebclr
Trash can for your PICKIT2
« Reply #8 on: June 28, 2016, 09:55:42 pm »
Don't do that , ins't worth your time and dedication , buy a discovery board instead
http://www.st.com/content/st_com/en/products/evaluation-tools/product-evaluation-tools/mcu-eval-tools/stm32-mcu-eval-tools/stm32-mcu-discovery-kits/stm32f4discovery.html
Avoid to be a "prisioner" of only one supply who have the higher cost development board and parts on the market. Go to the place where you will be supported for many different sources competing , and you will be the winner.
Offline ovnr
  • Country: no
  • Lurker
Re: Trash can for your PICKIT2
« Reply #9 on: June 28, 2016, 10:01:17 pm »
You really seem to have a hate on for Microchip, ebclr. Why?
Offline ebclr
« Reply #10 on: June 28, 2016, 10:05:15 pm »
I didn't hate I played a lot with microshit and this terrible compiler, but times passes and now it's clear arm is a much better option
Offline dannyf
« Reply #11 on: June 28, 2016, 10:25:36 pm »
Pics are much easier tto get started than the arm chips. And have a big code base to draw upon.
Arm chips offer much better value for your money.
A good compromise is msp432 if you have background in msp430.
Or lpc11 if you had lnp21xx experience.
Offline JPortici
« Reply #12 on: June 28, 2016, 10:31:48 pm »
:palm:
again, when was the last time you actually used a dspic or a pic32?
i damn each day i am forced to look at a STM32 datasheet
Offline macboy
« Reply #13 on: June 28, 2016, 11:13:28 pm »
That is true. The ATMega328P is 16 MHz and 16 MIPS. Lots of FLASH and RAM (32, 2 kB). PICs in the 16/18 series are mostly under 16 MIPS and have less memory, so at best you will be at par with the ATMega. You definitely need to go to PIC24 to move up, but it can be a good step up, with 16 bit native data size and more speed and memory. You can even find 5 V PIC24 if you want.
Don't feel held back by Arduino. For one thing, you can get much more powerful Arduinos (and clones) than the '328 based ones. Also, if you get under the hood a little, you can really supercharge a lot of the software environment, such as using interrupt directly, accessing registers directly for peripherals and I/O ports, bypassing the slow digitalWrite function, etc. There are limitations in the Arduino run time environment but none of it is written in stone. It is just software after all.
Offline stj
« Reply #14 on: June 29, 2016, 01:48:42 am »
actually it's 20MHz and 20MIPS
Offline macboy
« Reply #15 on: June 29, 2016, 02:20:31 am »
To be pedantic, as used in Arduino as the OP is talking about, it's 16 MHz.
« Reply #16 on: June 29, 2016, 03:20:50 am »
Thanks folks. Just to qualify, I'm not really an Arduino "graduate" but have run into some limitations using its abstraction. I dug out my pickit 2 and went rooting around for the IDE, then realized why I had forgotten about it. All that was on my old PC. Some of the chip naming conventions are coming back to me and I also found a few pic18lf14k50 chips I bought a while back, including a couple dsPIC303012 and slow 12-bit dacs. I'm going to have to run the crash course again before I can do anything and will look into getting a few more staples.
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
« Reply #17 on: June 29, 2016, 04:56:25 am »
I had the same 'issue' with Arduino. I opted for going deeper into the bare metal of the ATmega chips using Atmel Studio (Windows). I configured the avrdude-command line in the tools menu to program it - basically the same command line the Arduino IDE uses.
[2c]
Arduino Template Library | Zalt Z80 Computer
Wrong code should not compile!
Offline stj
« Reply #18 on: June 29, 2016, 05:26:29 am »
pickit2 can program AVR's with AVRdude.
incase you didnt know.  :-+
Offline Brutte
« Reply #19 on: June 29, 2016, 07:01:47 am »
Most PIC32 are serviced (debug + program) by PICKit2 via ejtagproxy.
Online hans
« Reply #20 on: June 29, 2016, 09:09:45 am »
 :=\ Another discussion about PIC32 derailed to STM32 and ARM.
Answering OP's question (with his intention to use his PICKIT2 in an useful manner):
I would strongly recommended skipping 8-bit PIC's. Compared to AVR's it's probably several steps backwards.
PIC24 is much more sane and alike AVRs.
One of my alltime favourite PIC24's is still the PIC24FJ64GB002/004. However unfortunately you can't debug it with PICKIT2 (need to program it via standalone utility).
Maybe look at the PIC24HJ128GP502; it seems to be supported in MPLAB. It's also 40MIPS and has a 12-bit ADC, but doesn't have an USB peripheral.
There are also some neat chips in the dsPIC series; but don't expect dsPICs to magically run faster. They have separate DSP instructions which you must program to be of use. In all other aspects they are basically PIC24s.
DAC's are uncommon on PIC's, or only available on the much newer ones.
You can program PIC32's too with either the ejtagproxy or some via the PICKIT2 standalone utility. I believe the PIC32MX3xx and PIC32MX4xx are supported. Don't fall for the 100MHz PIC32MX450 etc. ones; they are from a much more recent series which are not supported. E.g. PIC32MX440F512H
All other PIC series are not supported by PICKIT2 natively.
The device file that has been posted earlier is for use in the standalone program. You need to replace the .dat file in the programs folder to make device definitions available.
I'm unaware that the newer parts can be added. I think they use a different ICSP protocol or FLASH programming scheme and will not work.
« Last Edit: June 29, 2016, 09:13:00 am by hans »
Offline dannyf
« Reply #21 on: June 29, 2016, 12:59:28 pm »
"have run into some limitations using its abstraction"
Not sure the nature of your problems with arduino. But you do realize that you can code your arduino boards with a full fledged C compiler, either separately in an ide or in the arduino ide. So the abstraction should never be an issue even within the arduino environment.
Offline Howardlong
« Reply #22 on: June 29, 2016, 01:56:34 pm »
Indeed, it is rather tiresome and fruitless. The OP is asking about "PICs for my PICkit2".
I am not sure that the OP has a requirement for USB? Requirements were 10 bit ADC & DAC.
I'd agree with all that.
In the meantime, here's a supported list covering the original criteria where DACs are available on physical pins (I am making that final assumption, Many PICs have DACs only available internally for comparators).
Online Ian.M
« Reply #23 on: June 29, 2016, 03:34:53 pm »
I've put together a list of PICkit 2 supported PICs with full data from the Microchip parametric search page.  See attached spreadsheet in Excel 97 format.
I've added a couple of extra columns:-
  • 'MPLAB PK2 Support' - if its 'No' you need to use the standalone application with the unofficial 1.63.146 device file.
  • 'PK2 Debug / Header' - If its 'Yes' you can debug the PIC directly, if a debug header is listed, you need it, unless it is marked * which are optional headers.
N.B. All errors in the specs. are down to Microchip's buggy parametric search/device selector database - *ALWAYS* check the actual datasheet and errata before purchase
If you add a column titled 'Web', enter:
=HYPERLINK("http://www.microchip.com/wwwproducts/Devices.aspx?product="&TRIM(A2),"[x]") in the first cell below the title and fill down, you can click the '[X]' to jump directly from Excel to the product page for that PIC for easy access to the datasheet.
H.T.H.  ;)
« Last Edit: June 29, 2016, 03:44:55 pm by Ian.M »
« Reply #24 on: June 29, 2016, 03:49:29 pm »
Thanks All.
Howard, the dsPIC33FJ64GP802 looks most attractive.
Thanks for the Excel spreadsheet too as that makes finding a featured chip much easier.
