If you can upload the sketch to the logger via AS7, why worry about the boot loader?
Hello Phil
I don’t know how to upload the whole thing using AS7 I’m using the Arduino IDE so program the bootloader using SPI via the bus pirate. I then install a ftdi type interface to serial download the sketch via Arduino IDE.
In a perfect world I would just plug one of the original working sparkfun Openlogs int AS7 suck off the configuration and application code save it, then program the lot in one step into the Unconfigured openlogs from China. Is this possible?
I don’t really understand what I’m doing and I looking for a simpler method.
I’m also trying to figure out why the boot loader installed via AS7 does not work ?
Chris
