Hi all, how are you
I am using a Explained Pro Sam D21 .
I will control one AD5447 of 12 bits and I would like use the PB00 to PB11 pins.
I checked the DS of Sam D21 and discovered that PB04 to PB09 are analog pins, with power source of VDDanalogic, others pins VDDdigital.
Here is my doubt, could I use then as digital Pins? So I can define a MASK PB00 to PB11, it will be better to coding.
If no possible, I will need create an MASK with PA08 PA09 PA10 PA11 PA20 PA21 PA17 PA18 PA16 PA19 PA27 PA28. In this case my Mask will be confuse.
The MASK will have two source different, it can cause any instability?
This is a limitation of XplainedPro PCB
, I don't have the complete I/O port.
Have a nice saturday
Paulo
