found this Code, the orignal author is russian and so was the article. I have a spare ATMega8 and would like to put it on it. But the code uses timer/counter and PWM stuff, which is specific to ATMega328 family, can anyone help in porting it to ATMega8 specific timer/counters ?
here is the Code:
// Soldering station "JAY-936"
// Author - Chernyakov Sergey S. - [url=http://www.embed.com.ua]www.embed.com.ua[/url]
// Connecting an external file
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include <avr/eeprom.h>
#define DIG1 PB0 /*Cathode 1-st digit indicator */
#define DIG2 PB6 /*Cathode 2-nd digit indicator*/
#define DIG3 PB7 /*Cathode 3-rd digit indicator */
#define DIG4 PD7 /*Cathode 4-th digit indicator */
#define PORT_DIG1 PORTB /*Port cathode 1st digit indicator */
#define PORT_DIG2 PORTB /*Port cathode 2st digit indicator*/
#define PORT_DIG3 PORTB /*Port cathode 3st digit indicator */
#define PORT_DIG4 PORTD /*Port cathode 4st digit indicator */
#define BUZZER PB2 /*Output buzzer*/
#define PORT_BUZZER PORTB /*Port buzzer*/
#define DDR_BUZZER DDRB /*Register Direction buzzer*/
#define LED PC4 /*Output LED*/
#define PORT_LED PORTC /*Port LEDs*/
#define DDR_LED DDRC /*Register LED direction*/
#define BUTTON PC3 /*Login button*/
#define PORT_BUTTON PORTC /*Port button*/
#define DDR_BUTTON DDRC /*Register direction buttons*/
#define PIN_BUTTON PINC /*Contact button*/
#define ENC_0 PC0 /*0-its entrance ýnkodera*/
#define ENC_1 PC1 /*1st encoder input*/
#define PORT_ENC PORTC /*Port encoder*/
#define DDR_ENC DDRC /*Register direction encoder inputs */
#define PIN_ENC PINC /*Contact encoder inputs*/
#define Vdd 4930 /*Supply voltage - reference for the ADC*/
#define PI_PIP TCCR2B |= (1 << CS21) | (1 << CS20) /*Macro for buzzer (pi) beeping*/
const unsigned char cifra [] = {0x77,0x44,0x5B,0x5E,0x6C,0x3E,0x3F,0x54,0x7F,0x7E};// An array of codes to form figures
unsigned char sot, des, edi, EncState;
unsigned int *a;//A pointer to the display value (setting encoder / actual temperature)
volatile unsigned int Temperature, time, EncData, pwm, status;
enum {work, sleep};
void podsvet (void) //Display values Function
static unsigned char q;//Indoor counter Display category
q++;
switch(q) //Bust discharge Display Now
case 1:PORT_DIG4 &= ~(1 << DIG4);//Gasim Previous rank
PORTD &= 0x80; PORTD |= cifra[edi];//Set the corresponding number
PORT_DIG1 |= (1 << DIG1);//Highlights by following discharge
break;
case 2:PORT_DIG1 &= ~(1 << DIG1);
PORTD &= 0x80; PORTD |= cifra[des];
PORT_DIG2 |= (1 << DIG2);
break;
case 3:PORT_DIG2 &= ~(1 << DIG2);
PORTD &= 0x80; PORTD |= cifra[sot];
PORT_DIG3 |= (1 << DIG3);
break;
case 4:PORT_DIG3 &= ~(1 << DIG3);
PORTD &= 0x80; PORTD |= 0b00101011;//In the fourth permanent illumination of the discharge letter t // cifra [tis];
PORT_DIG4 |= (1 << DIG4);
q=0;//As highlighted in the last 4-th bit counter reset
break;
default:
break;
void EncoderScan(void)//encoder processing function
unsigned char New;//Partly new value encoder
New = PIN_ENC & ((1<< ENC_0) | (1 << ENC_1));// Read the current position of the encoder
if(New != EncState)//If the value has changed compared to the previous
switch(EncState) //Enumerating the last value encoder
case 2:if(New == 3) EncData++;//Depending on the increase
if(New == 0) EncData--;//Or reduce
break;
case 0:if(New == 2) EncData++;
if(New == 1) EncData--;
break;
case 1:if(New == 0) EncData++;
if(New == 3) EncData--;
break;
case 3:if(New == 1) EncData++;
if(New == 2) EncData--;
break;
default:break;
if(EncData > 360) EncData = 360;//Be careful not to go beyond the top
if(EncData < 200) EncData = 200;//and lower limit
EncState = New; // We write the new value of the previous state
a = &EncData;//Pointer to assign an address encoder current value (set temperature)
TCCR0B = TCNT0 = time = 0; //Timer 0 is stopped and reset
TCCR0B |= (1 << CS02) | (1 << CS00);//And restart for reference 3 seconds and 15 minutes
PI_PIP;//Pipiknut for confirmation hearing
void A_D_C (void)//ADC service function
static unsigned long Usum;
static unsigned int i;
ADCSRA |=(1<<ADSC); // Run ADC
while(!(ADCSRA & (1<<ADIF))); // Wait for the end of conversion
ADCSRA |=(1<<ADIF); // Reset completion flag conversion
Usum += ADCW; //Summarize the ADC values to calculate the average (eliminating the "twitch" bits)
if(i++ >= 300) //If a 300 times already measured
Temperature = (((Usum/300)*Vdd)/1023)/10;//Calculate the value of the temperature
Usum=i=0; //voltage and reset the counter
ISR (TIMER0_OVF_vect) //Timer 0 - for the reference time interval (overflow ~ 32ms)
static unsigned int p,l;//Counters for "baking" and flashing LED in sleep mode
if (status == work)//If the status of the work
time++;//Increase the counter overflows
if(time < 91)//If less than 3 seconds after the installation of the encoder temperature
if(bit_is_clear(PIN_BUTTON, BUTTON))
eeprom_write_word(0x10, EncData);//when you press the button to record the value in the EEPROM
PI_PIP;//and pipiknut
if(time >= 91) //If it has been 3 seconds = 32 ms x 91
a = &Temperature; //Pointer assign the address of the current tip temperature
if(time >= 28125) //If it's been 15 minutes
TCNT0 = 0; //Timer 0 reset
TCCR1B = TCCR1A = 0;//PWM stop
time = 0;//Reset the counter overflows
status = sleep;//Go to "sleep"
else if (status == sleep)//If the state DREAM
if(p++ >= 500) p = 0;//Increment counter for Tweeters not go beyond
if(p == 4) PI_PIP;//Pipikaem four times every ~ 15 seconds
if(p == 8) PI_PIP;
if(p == 12) PI_PIP;
if(p == 16) PI_PIP;
if(l++ >= 60) l = 0;//Increase the count for the LED does not go beyond
if(l == 4) PORT_LED |= (1 << LED);//Morgan twice every 2 sec
if(l == 8) PORT_LED &= ~(1 << LED);
if(l == 12) PORT_LED |= (1 << LED);
if(l == 16) PORT_LED &= ~(1 << LED);
ISR (TIMER1_OVF_vect) //Timer 1 - for maintenance Shimano (overflow ~ 65 ms)
if (Temperature < EncData) //If the actual temperature is less than the encoder
if(pwm++ > 1023) pwm = 1023;//Increase the heat, do not go beyond the boundaries of the PWM
if (Temperature > EncData) //If the actual temperature exceeds the set encoder
if(pwm-- <= 0) pwm = 0; //Reduce the heat, do not go beyond the boundaries of the PWM
if (Temperature == EncData) //If the actual temperature is set encoder
pwm = OCR1A; //We leave everything as it was
OCR1A = pwm; //Write a heating value in the comparison register
ISR (TIMER2_OVF_vect) //Timer 2 - for Tweeters
static unsigned char w;//Variable defining the duration of the "pi-beeping"
if(w++ < 100) PORT_BUZZER ^= (1 << BUZZER);//If the duration is not over - change the state of the output to the opposite (square wave)
else //If the duration is over
w=0;//Counter reset duration
TCCR2B = 0;//Timer stop
int main (void)
DDRD = 0xFF;//outputs for display
DDRB = 0xFF;//
DDR_BUZZER |= (1 << BUZZER);//Output for Tweeters
PORT_BUZZER &= ~(1 << BUZZER);//with zero
DDR_LED |= (1 << LED);//Output for LEDs
PORT_LED |= (1 << LED);//Highlighting to indicate power-on
DDR_BUTTON &= ~(1 << BUTTON);//Login button
PORT_BUTTON |= (1 << BUTTON);//a pull-up resistor
DDR_ENC &= ~(1 << ENC_0);DDR_ENC &= ~(1 << ENC_1); //Inputs for encoder
PORT_ENC |= (1 << ENC_0) | (1 << ENC_1);//a pull-up resistor
TIMSK0 |= (1 << TOIE0);//Interrupt Enable timer 0 overflow
TCCR1A |= (1 << WGM10) | (1 << WGM11) | (1 << COM1A1);//10-bit Phase correct PWM, the output is connected OC1A (neinventirovanny PWM)
TIMSK1 |= (1 << TOIE1);//Interrupt Enable Timer overflow 1
TCCR1B |= (1 << CS11);// | (1 << CS10);//Start Timer 1 prescaler 64
TIMSK2 |= (1 << TOIE2);//Interrupt Enable Timer overflow 2
ADMUX |= (1 << REFS0) | (1 << MUX2) | (1 << MUX0);//Reference voltage - supply voltage, 5 th ADC channel
ADCSRA |= (1 << ADEN) | (1 << ADSC) | (1 << ADPS2) | (1 << ADPS1);
EncData = eeprom_read_word (0x10);
status = work;
sei();
for (;;)
if(status == work) EncoderScan();
A_D_C ();
sot = ((*a)%1000)/100;
des = (((*a)%1000)%100)/10;
edi = (((*a)%1000)%100)%10;
podsvet();
here is the error log
Compiling C: Soldier_exm.c
avr-gcc -c -mmcu=atmega8 -I. -gdwarf-2 -DF_CPU=8000000UL -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=./Soldier_exm.lst -std=gnu99 -Wundef -MMD -MP -MF .dep/Soldier_exm.o.d Soldier_exm.c -o Soldier_exm.o
Soldier_exm.c: In function 'EncoderScan':
Soldier_exm.c:104: warning: assignment discards qualifiers from pointer target type
[b]Soldier_exm.c:106: error: 'TCCR0B' undeclared (first use in this function)[/b]
Soldier_exm.c:106: error: (Each undeclared identifier is reported only once
Soldier_exm.c:106: error: for each function it appears in.)
[b]Soldier_exm.c:108: error: 'TCCR2B' undeclared (first use in this function)[/b]
Soldier_exm.c: In function '__vector_9':
Soldier_exm.c:141: warning: passing argument 1 of '__eewr_word_m8' makes pointer from integer without a cast
[b]Soldier_exm.c:142: error: 'TCCR2B' undeclared (first use in this function)[/b]
Soldier_exm.c:147: warning: assignment discards qualifiers from pointer target type
Soldier_exm.c: In function '__vector_4':
[b]Soldier_exm.c:200: error: 'TCCR2B' undeclared (first use in this function)[/b]
Soldier_exm.c: In function 'main':
[b]Soldier_exm.c:217: error: 'TIMSK0' undeclared (first use in this function)
Soldier_exm.c:220: error: 'TIMSK1' undeclared (first use in this function)
Soldier_exm.c:223: error: 'TIMSK2' undeclared (first use in this function)[/b]
Soldier_exm.c:227: warning: passing argument 1 of '__eerd_word_m8' makes pointer from integer without a cast
make.exe: *** [Soldier_exm.o] Error 1
> Process Exit Code: 2
> Time Taken: 00:11
any help would be appreciated. Have already etched the pcb and populated it with other components.
