On the subject of this thread, why would an algorithmic step call for shifting a 32 bit quantity by 32 or more bits in one operation? It's not a question of what the compiler or hardware do with this operation, it is about why do you logically need this operation to occur in your design?
I am moving my GPS receiver code from processing one sample at a time to processing 32 bits at a time. Because of pesky things like Doppler shift, sometimes a chip spans 15 samples, or other times it might span 17 samples - the upshot is that the phase isn't fixed, and slowly creeps. Because the sample rate is 16x the nominal Gold code chip rate the nominal 'chip' rate, 32 samples might cover up to three different code 'chips':
e.g. at one given point in time I might be 11111111111100000000000000001111, with the first set of 1s from bit 1021 of the gold code, the set of 0s from bit 1022, and the last set of ones is from bit 0 of Gold code (the codes are 1023 bits long).
I also need to create a mask, that represents which bits are in the next repetition of the Gold Code. in this case the mask will be 00000000000000000000000000001111, as the last four 1s are from the next repeat of the Gold Code.
I tripped over this issue, as I had 'n0' being the count of repeats from the oldest code bit. 'n1' being the count of bits from the middle code bit, and 'n2' being the count of bits form the most recent code bit - so as you would expect n0+n1+n2 = 32.
To make the mask quickly I am taking 0xFFFFFFFF, and then shifting it right by (n0+n1) - wanting branchless code for speed:
mask = 0xFFFFFFFF;
mask >>= n0+n1;
When the phase was such (or the doppler shift was such) that no bits were used from the most recent code bit it would mask out all the bits.
So now I am using this, and it is fine.
mask = 0xFFFFFFFF;
mask >>= n0;
mask >>= n1;
So it is a real world need / use case. It just was an interesting previously unknown behavior to me!
