I am trying to add a storage device to my 68K board, I'd like to have something as big as possible
my board has 5 slots, each slot is capable to address up to 16 Mbyte over a 32bit parallel bus
currently in use chips
DS1265Ychips, whose datasheet claims:
- fully static nonvolatile SRAMs organized as 1,048,576 words by 8 bits (1Mbyte)
- 5 years minimum data retention in the absence of external power
- Data is automatically protected during power loss
- Unlimited write cycles
the above PCB draft shows the initial idea where I planned to use four NVRAM, in the theory I have enough space on the each DIP socket to address 4 Mbyte per chip, but I can't practically find anything greater than 1Mbyte (I mean at cheap price, a NVRAM chip of 2Mbyte (1) costs too much), so the ram disk is going to be (1x4=) 4Mbyte of total storage size, just because I found 4 chips shipped for 50 euro (second hand, and they work fine).
OK, so here we are with the topic questions: what do you suggest, guys ? FeRam ?
Do you know a cheap FeRam chip, which comes with 3.3V/5V, 8bit data interface, 2..4Mbyte per chip ?
All of this, at cheap price ? (say, "it's cheap", if it costs a quarter than Dallas price for their NVRAM)
thanks
(1) e.g.
DS1270Y, 2Mbyte
edit:
ops, I had forget to underline:
it MUST be non volatile, I mean able to retain information once switched off
