if you want people to understand you are doing a unique serial debug test port for a digital device, don't copy an industry standard serial debug port for your name.
renamed into "Otaku"
That solves that.
the importance of being called "Otaku"…. that sounds like dry sarcasm under the hood of its Etymology, especially when one got applied the term to unpleasant fans in caricature, as in modern Japanese slang, the term otaku is mostly equivalent to "
geek" or "
nerd", but in a more derogatory manner than used in the West, but it makes sense: even if it is more used for people with obsessive interests, commonly the anime and manga fandom, "Otaku" is also a Japanese term for
another person's house or family, describing an open-roofed entrance hall or central court in an ancient house, while in modern buildings it is simply a room used for entry from the outside, sometimes referred to as a foyer or an entrance hall, in short it means "lobby room", and in my head sounds like "test point", as one doesn't need to be a
Japanese-
Sherlock Holmes to realize that … you can understand something about the house's owner just from the entrance, hence "tap", which stands for test access point (to my debug engine) has become the japanese name for "entrance point", and we are feeling fine
(kidding with Japanese and English, two languages that I wish I was able to master
