Author Topic: Rolling my own computers in the 90s  (Read 15271 times)
Online joeqsmithTopic starter
« on: February 15, 2016, 01:43:59 am »
I had posted a video some time ago about a small computer I had designed using a small FPGA back in the 90s.   This was not the first computer I had designed.   I pulled out one of my old PCs today take a few pictures of my last CPU prototyping board.   The board talks with the PC using a 16-bit ISA bus.   It has some static and dynamic RAM along with some FLASH.   The two larger FPGAs were programed from the ISA bus.   The FPGA in the PGA package performed the ISA bus interface, output the post codes, controlled a DDS the clocked the two larger FPGAs, as well as simulated the Altera programmer and security key.
Offline DJLinux
Re: Rolling my own computers in the 90s
« Reply #1 on: February 15, 2016, 11:45:43 am »
Good job I like it.
Currently a play with an very cheap ALTERA CycloneII EP2C5T144C8 board.
Where do you get this funky ISA prototype boards from ?
DJ
« Last Edit: February 15, 2016, 11:50:34 am by DJLinux »
(sorry about my bad english)
Offline legacy
« Reply #2 on: February 15, 2016, 12:23:03 pm »
@joeqsmith
what was the purpose of your ISA board?
here I have an article, written in german, which talks about parallel computing over 68020 modules plugged into a PC on ISA16 bus
Offline jboard146
« Reply #3 on: February 15, 2016, 04:12:04 pm »
Awesome!
« Reply #4 on: February 15, 2016, 05:24:32 pm »
Good job I like it.
DJ
Back then, many places sold them.  I believe the larger 16-bit ISA board was made by Vector and I am guessing I bought it from Digi-Key.  Some I picked up from Jamaco and Newark.
@joeqsmith
Really like most of my hobby projects, it was just for fun.  The board itself was designed to try some different ideas on how to design my own CPU.
Awesome!
Thanks!  My plan was to put together a video showing how it all works.
Offline legacy
« Reply #5 on: February 15, 2016, 07:25:41 pm »
my own CPU
is it RISC ? CISC ?
like R2K? like z80? 6800? 68000?
In my case, I am inspired by eight eight key, 88k
I am studying its User Manual
« Reply #6 on: February 15, 2016, 11:43:23 pm »
my own CPU
is it RISC ? CISC ?
I assume you did not watch the video.   For the one in the video, I coded up the instruction set in a language I wrote that is similar to assembler.   These codes then define each op-code.   the instruction set is very similar to a Motorola 6801/11.  However I had added some of my own op-codes ti the mix.   I then wrote my own assembler for it.   It could run 6801 code directly except I did not try to follow the same number of clock cycles per instruction.   It runs much faster than the original part as well.
The wire-wrap board shown in the pictures is really just a CPU prototyping setup.   It was not designed around any particular style of instruction sets.
If you wanted to do this today, I would guess that the majority of evaluation boards would have much better hardware than what I had available back then.
Offline legacy
« Reply #7 on: February 16, 2016, 01:50:11 am »
yes, I am not able to play video with the machine I am currently logged-in
my 2011-mid bookAir has just died and I planning to buy a new one laptop (it won't be Apple)
so, currently I am using my old Unix Workstation, which comes with Netscape
it's a funny 90s browser, but it's not able to play videos
by the end of the next week I will get hands on my new laptop  :-+
Offline legacy
« Reply #8 on: February 16, 2016, 01:52:26 am »
here I have a similar problem: I have developed a new ISA(1), so I also need to develop a new assembler.
as you did, I have written myown assembler, too, and It works fine, but it does not support the linker,
instead, it builds the final binary directly
.asm ----> .{ bin, s19 }
supporting row binary(bin), and SREC(s19)
  • out.data.{bin,s19} contain the data-section
  • out.code.{bin,s19} contain the code-section
for this reason my assembler abuses of the #include directive, and everything (procedures, modules, etc) is an "include"
I have also developed a special tool that stuff the above row binaries into rom.vhdl
it's useful with you work with fpga
(1) similar to eight eight key, 88K, by Motorola
I have been working on my TAP (debug processor) for 3 years, just 3+3 hours a week during the week end
« Reply #9 on: February 16, 2016, 02:28:40 am »
Funny,  the video board in my old desktop died a couple of weeks ago.  Shorted out the power supply.   I need a new PC too, but need something with at least 1 PCI slot.
That's been many years ago but I think I just made a simple single pass assembler for the microcode.  It will take me a little time to figure out what all I was doing back then.   The PC is back together and will at least boot.   I had written some diagnostics for the board that load in a couple of test cores then exorcises the memory and buses.  I found the cables that go with it, so I plan to try testing the board in the next day or two.   These things never go smooth.
TAP as in JTAG? Are you trying to make a computer that is geared toward JTAG specific control?    If so, do you have a blog where you are posting your progress?   I am interested!     I have written code by had for some of the Motorola parts using the BDM as well as JTAG.   What a nightmare.   If I were to do it today, it would be an FPGA with a FSM and Ethernet interface to the PC.
Project for school, work or just for fun?
Offline legacy
« Reply #10 on: February 16, 2016, 02:20:04 pm »
yes and no
yes, T.A.P. stands for a Test Access Port, for monitoring the internal memories of the CPU, and this pushes you in the direction of IEEE 1149.1 JTAG
because JTAG is needed for detailed testing and instrumentation of the CPU, for instance to capture or replay pipeline stalls, hazards, and exceptions.
but no, JTAG only has access to I/O pins, so, to implement real emulators and trace tools you must have a logic block with special access to internal data and control paths and things become boring and complex (e.g. see the JTAG-ADI bridge made by the OpenRisc team), while in my case the TAP is just  the interface to the debug processor, which talks to the host over a serial protocol (different from SWD)
it works with CISC design, marvelously, It can be adapted to RISC (including pipeline, and superscalar pipeline, and multi core superscalar pipeline)
this part is underdevelopment, and it might be put in business, while the CISC design was born to "pass" a computer science examination in my university
unfortunately no
MC68332? Here I have a BCCDI board, it comes with an hardware debug processor which talks over the serial line to the host. I have asked a friend to revers its protocol, and he has reported good news about that. We have a RiscPC, equipped with a PC-card, and a BDM cable attached to the LPT port. I can ask him to reverse  the BDM protocol (by a LA attached on the interface), as it's not well documented.
« Last Edit: February 16, 2016, 08:06:43 pm by legacy »
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
« Reply #11 on: February 16, 2016, 05:27:46 pm »
That wiring alone is awesome!
Arduino Template Library | Zalt Z80 Computer
Wrong code should not compile!
« Reply #12 on: February 16, 2016, 11:58:10 pm »
Thanks.  Glad those days are gone!
For BDM the 331, 332 and the 376.     For JTAG, the 306.    In both cases I wrote the code to bit bang the printer port.  Slow but very effective for bringing up the hardware for the first time.
Offline legacy
« Reply #13 on: February 17, 2016, 12:02:35 am »
is there a public project? in our case (my friend and I) we will embed the BDM protocol into a cpld
so it will talk my TAP protocol, and it will connect to 332, in short it will be a BDM-TAP bridge
« Reply #14 on: February 17, 2016, 01:30:47 am »
It was for work some 20 years ago.   I did it for fun at home but used it for work.   Basically I was using the ports to test the hardware and identify any problems then program the boards.  The BDM was no problem but the the JTAG was pretty slow.
Pictures showing my first prototype JTAG adapter.
« Reply #15 on: February 18, 2016, 12:54:01 am »
Here is the first video of the set.   Enjoy.
Offline crispy_tofu
« Reply #16 on: February 18, 2016, 05:51:46 am »
Very cool.  :-+
« Reply #17 on: February 18, 2016, 12:13:39 pm »
Very cool.  :-+
Thanks.  With any luck, the board will still run.   I powered up the PC and it looks like at least it still runs.
Offline bson
« Reply #18 on: February 19, 2016, 05:43:58 am »
Wooow!  Glad not to ever have to wirewrap again for prototyping... Cheap PCBs FTW!!!
« Reply #19 on: February 23, 2016, 12:34:04 am »
Agree.  I used to have a slit wrap spool gun when I was doing a lot of it.   These were all done by hand.
Looks like the board is still functional.
Offline legacy
« Reply #20 on: February 23, 2016, 01:23:05 am »
Your work is impressive  :o :o :o :o
« Reply #21 on: February 23, 2016, 03:10:45 am »
The first version was done to pass a computer science examination (I got the result of 27/30 by my "computer architectures II, laboratory" professors , which is a decent vote, not brilliant), the second version attempts to be an hobby fun, the above is the simulator I wrote in order to reinvent the wheel, as I have designed a completely new ISA (it's RISC-like), which comes with its debug processor over its TAP, it stands for test access point, which is not jtag, and talks on the serial console with its own protocol.
No need to explain.  I have a copy of the IEEE 1149.1 standard, which was created by the JTAG subcommittee.
Offline legacy
« Reply #22 on: February 23, 2016, 09:38:20 am »
No need to explain
so, I believe I'd better choose a more hipster name for the test access point of my debug processor inside the Arise processor, otherwise those guys in IEEE 1149.1 standard, which was created by the JTAG subcommittee, will ask me to pay the Copyright, and people will be not impressed (I apparently have already heard that name, uuuu  :-//) or confused (I have definitely already heard that name and it's already used to describe other things, my disappoint :palm: )
feel free to suggest me a funnier (1) one for Arise v3
(1) constrains: causing laughter or amusement, humorous, witty, comic, comical, droll, facetious, jocular, jockey, hilarious, hysterical, riotous, uproarious, entertaining, diverting, sparkling, scintillating, silly, farcical, slapstick, side-splitting, rib-tickling, laugh-a-minute, wacky, zany, off the wall, a scream, rich, priceless, difficult to explain and understand, strange
(kidding :D )
« Reply #23 on: February 25, 2016, 03:15:37 am »
No need to explain
(kidding :D )
I never picked up that that you were calling TAP had nothing to do with the industry standard TAP until now.
I'm assuming  when you write BDM you actually mean Motorola's BDM standard.   Do they even sell the 332 anymore?   What is what you call TAP doing that I can't achieve with the BDM?   I tested a lot of hardware with that BDM port using nothing more than a GAL, a printer port and some C code.   I still have an old HP BDM interface along with the P&E.
Offline legacy
« Reply #24 on: February 25, 2016, 05:18:46 pm »
witten in this topic, just a few posts above
Quote from: ivelegacy
if I do not tell you what an acronym is referring to, you can assume it's within the common standard, and in this case, BDM is Motorola BDM
my TAP is currently used in my Arise Softcore, which I have implemented in fpga. A software simulator (see the above post) is also existing as proof of concept.
Concerning my 332 board, I am going to build a bridge between my TAP and BDM, in this case the interface to MC68332 will be BDM, while the interface to my host PC, and all the software I have written to handle it, will be TAP
my Eprom emulator is also able to talk my TAP, as my TAP comes with a flexible protocol
Offline legacy
« Reply #25 on: February 25, 2016, 05:24:09 pm »
my tap is usb-driven, I am going to use a modern linux/arm board, which has two usb ports, unfortunately no printer or usable gpio port
« Reply #26 on: February 26, 2016, 02:41:42 am »
I read it, saw serial debug port and TAP in one sentence and thought TAP.  Seems like if you want people to understand you are doing a unique serial debug test port for a digital device, don't copy an industry standard serial debug port for your name.
When I was using the TAP, that CPU had no provision to do anything beyond control the I/O.  Most of what I see it used for is an easy way to test interconnects.
Why would you waste time on the 332 is what I don't get.  Such an old, obsolete part.  Why not pick something at least of this decade to showcase your TAP?
Offline legacy
« Reply #27 on: February 26, 2016, 01:13:06 pm »
renamed into "Otaku"
obsolete means nothing, 332 is a good machine, it provides a good debug port, I like it, and that's all.
in first place because modern things come with jtag, or swi, and I do not like them
things like OpenRisc come with adi-jtag bridge, and again I do not like them
also I have no time and effort to support them
Otaku has been developed to help during the development of the Arise core
it's also useful to support my eprom emulator, and my VDU (video display unit)
it's exactly what I need as "swiss knife" to be used in fpga development, and it also helps in software debugging.
« Reply #28 on: February 27, 2016, 09:32:34 pm »
That solves that.
Offline legacy
« Reply #29 on: February 28, 2016, 03:29:17 pm »
That solves that.
the importance of being called "Otaku"
…. that sounds like dry sarcasm under the hood of its Etymology, especially when one got applied the term to unpleasant fans in caricature, as in modern Japanese slang, the term otaku is mostly equivalent to "geek" or "nerd", but in a more derogatory manner than used in the West, but it makes sense: even if it is more used for people with obsessive interests, commonly the anime and manga fandom, "Otaku" is also a Japanese term for another person's house or family, describing an open-roofed entrance hall or central court in an ancient house, while in modern buildings it is simply a room used for entry from the outside, sometimes referred to as a foyer or an entrance hall, in short it means "lobby room", and in my head sounds like "test point", as one doesn't need to be a Japanese-Sherlock Holmes to realize that … you can understand something about the house's owner just from the entrance, hence "tap", which stands for test access point (to my debug engine) has become the japanese name for "entrance point", and we are feeling fine :D :D :D :D
(kidding with Japanese and English, two languages that I wish I was able to master  ;D)
