No, I just did quick search if there was anything like it.
Google bring up this:
https://github.com/JuanLuisGonzalez/ATC-Release-Codes?files=1No android side code as it is not free?
Seems like the datasets on total control are fixed and on android side the created layout just tapes together desired I/O to the receiving end.
Sending data from micro is the smae
Back on track.
So basically when prototype C function is called on tablet/micro, it pulls up the interface to communicate with the micro/tablet to run a function and returns the result for the tablet/micro to process. So at minimum function ID, parameters and their count/type upstream and result/type downstream.
Automating the code generation for the communication on micro and android when a function prototype is defined is the goal?
I might have missed it a bit as I assumed there was a need to generate one application with all code, where some code was defined to be ran on the micro only and some on androind only, my train of thought littlebit too complex...
