You see an awful lot of gear, like sensors, pressure gauges, etc. that has RS232 or 422/485 interfaces, to hook up to some digital control system, and I've looked at some datasheets for these, specifically vacuum gauges, without much hints about how the interfaces are designed.
Getting any sensor to talk to a computer or terminal via some flavor of serial is of course pretty trivial, what I'm talking about is how the interface itself is made, might there be a standardized way of doing things like this?
-Does a sensor just spew endless readings through serial one-way?
-Do they require a "get reading" character/command rx'd to respond?
-Is it common that they just have a menu, with setup options, get reading, and such?
See, if you have this sorta thing hooked to a datalogger, just getting data sprayed (or timed every n sec/min/day) would sound the most logical.
But if the data system is a terminal, that would hardly let you read anything, so a two-way thing would be preferred. Though that would suck for a datalogger sorta thing.
Is there a standardized way of doing this, or is it just whatever the equipment manufacturer chooses?
