Unabridged paste:
pi@raspberrypi:~/bootloader $ sudo openocd
Open On-Chip Debugger 0.10.0-dev-00371-g81631e4 (2016-09-16-10:19)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
BCM2835 GPIO nums: swclk = 25, swdio = 24
srst_only separate srst_gates_jtag srst_push_pull connect_deassert_srst
adapter speed: 400 kHz
cortex_m reset_config sysresetreq
adapter_nsrst_delay: 100
adapter_nsrst_assert_width: 100
Info : BCM2835 GPIO JTAG/SWD bitbang driver
Info : SWD only mode enabled (specify tck, tms, tdi and tdo gpios to add JTAG mode)
Info : clock speed 400 kHz
Info : SWD DPIDR 0x0bc11477
Info : at91samd21g18.cpu: hardware has 4 breakpoints, 2 watchpoints
TargetName Type Endian TapName State
0* at91samd21g18.cpu cortex_m little at91samd21g18.cpu halted
at91samd21g18.cpu: target state: halted
target halted due to debug-request, current mode: Thread
xPSR: 0x61000000 pc: 0x2000002e msp: 0x20007fe4
** Programming Started **
auto erase enabled
Info : SAMD MCU: SAMD21G18A (256KB Flash, 32KB RAM)
wrote 16384 bytes from file samd21_sam_ba.bin in 1.037158s (15.427 KiB/s)
** Programming Finished **
** Verify Started **
verified 5972 bytes in 0.027730s (210.315 KiB/s)
** Verified OK **
target halted due to breakpoint, current mode: Thread
shutdown command invoked
