Author Topic: Segger J-Link EDU or J-Link clone, which one would you get?  (Read 80632 times)
Offline 0xdeadbeef
Re: Segger J-Link EDU or J-Link clone, which one would you get?
« Reply #75 on: January 22, 2016, 11:18:50 am »
But that's what he asked for!?
... use loadbin to load an M0 program into SRAM instead of Flash
« Last Edit: January 22, 2016, 11:20:29 am by 0xdeadbeef »
Offline abyrvalg
« Reply #76 on: January 27, 2016, 07:26:30 pm »
Like to reprogram you can use "loadbin" and to dump "savebin". Details are described in the J-Link user manual.
It's not fancy, but should provide the same functionality as J-Flash.
It doesn't. J-Flash has flash loaders and sector maps for this, commander doesn't.
Offline 0xdeadbeef
« Reply #77 on: January 27, 2016, 08:07:56 pm »
I'm not sure I can follow you there. As far as I recall, you can program bin files at any address, J-Link Commander will erase the sectors automatically and select the correct flash algorithm. So it has to know the flash sector map and it has to have proper flash algorithms (if that is what you mean with "loaders"). That's why you have to select the device. Actually, you can do quite a few things that J-Flash can't like setting breakpoints and the like, but I never did this.
Admittedly, the command line interface is something to get used to, but you can put all the commands in a script and execute that from a batchfile or whatever.
A 2nd problem with programming through J-Link Commander is that it only accepts binary (bin) files. However, even without a license, you can use J-Flash to create a bin from hex/mot to bin.
And of course there are lots of other tools for hex/mot/bin conversion.
Anyway, there is also a little tool called "J-FLash Lite" in the default software package that let's you reprogram through a minimalist GUI without a J-Flash license if that's what you want.
Unfortunately, whoever did this was too lazy to allow sizing of the initial device selection dialog, so you can't read the text if you're using a non-standard text size (DPI scaling > 100).
That's something you could excuse for a ten year old in his/her 1st program. Even as free tool in a commercial package, it's somewhat embarrassing. Still, it works. Any hey, you can even load mot/hex directly.
Letting aside the GUI scaling issues, the only things J-Flash Lite can't do is to dump or to unlock the device if this is needed. Then you need to go back to J-Link Commander.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #78 on: May 05, 2016, 07:04:22 pm »
Everything you need to know is here
Way too complicated and unnecessary.
not necessarily complicated. just follow/download SAM-BA guide as discussed there if the clone is bricked, download fw from http://www.vxworks6.com/2beanet/embedded/arm/458-jlink-v8-schematic-and-firmware.html as ones backup. edit some bytes in the *.bin and *.dll at some location offsets. i think i can follow it, much easier than cracking the rigol dso fw i guess. but since my clone is working with uVision5 now (by resisting upgrade) i dont need to do all that for now, but i'm documenting and downloading the necesssary files in case i need it in the future... in case you need the latest driver rev, just crack 1 or 2 bytes in the *.dll as outlined there..
Offline GromBeestje
« Reply #79 on: July 30, 2017, 06:12:13 pm »
Segger has recently released a new model, EDU mini, ( https://www.segger.com/news/segger-introduces-j-link-edu-mini-a-low-cost-j-link-for-education/ )
for only € 17,85.
The following users thanked this post: evb149
Offline Sal Ammoniac
« Reply #80 on: July 31, 2017, 04:58:09 pm »
for only € 17,85.
Interesting. Thanks for posting that.
It looks like the big differences between it and the standard J-Link are: 1/5 the download speed, SWD only. The Segger website implies that it only supports Cortex-M (the standard J-Link supports ARM7/9 and Cortex-A/R/M).
Complexity is the number-one enemy of high-quality code.
Offline marshallh
    • retroactive
« Reply #81 on: August 03, 2017, 03:45:59 am »
Rev 10 J-Link edu
Verilog tips
BGA soldering intro
Offline mac.6
« Reply #82 on: August 03, 2017, 08:40:41 am »
for only € 17,85.
It's pretty much the J-link you got on some dev board. Fully functional but slow.
Offline thm_w
  • Non-expert
« Reply #83 on: August 04, 2017, 10:11:22 pm »
Its a bit annoying that they only mention the speed limitation in this news release. I read the product page: https://www.segger.com/products/debug-probes/j-link/models/j-link-edu-mini/ and manual and didn't notice it anywhere there.
Its nice to see though, the fact that $2 stlinks have been around for a while seemed to stir up some innovative ideas.
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #84 on: August 07, 2017, 06:30:00 am »
I am wondering this: what if I bought a J-Link clone, took it apart, and loaded CMSIS-DAP firmware on it before using it?
Also what if I took the J-Link clone (with the likely pirated or reverse engineered Seeger firmware,) but instead of using the Segger software, used OpenOCD from day one?
Also what if instead of the clone I did the above using a genuine J-Link EDU?
Offline ehughes
« Reply #85 on: August 10, 2017, 11:49:21 am »
Jlink + Ozone is worth the price.    Get a real one and don't support the clones.
The following users thanked this post: rsjsouza
« Reply #86 on: August 10, 2017, 03:57:10 pm »
Hear hear! Companies should compete with Segger by developing a better product, not by copying their existing product.
The following users thanked this post: Kalvin, Heszu
Offline zelea2
« Reply #87 on: December 28, 2020, 09:20:12 pm »
Read this if you want to see the differences between a genuine and clone J-Link
https://uglyduck.vajn.icu/ep/archive/2019/05/Unbricking_a_SEGGER_J_Link_v9_debug_probe.html
The following users thanked this post: photovore, thm_w
