Author Topic: Segger JLink - Worth it for hobby use ?  (Read 5131 times)
Offline alin_im
« on: August 20, 2017, 10:19:31 pm »
Hey guys,
I am thinking of purchasing a Segger JLink EDU, is it worth it for hobby use ? I have some past experience with MCUs, but I want to get a little bit more serious with them.
My job is not in embedded systems so I will purchase for personal use. I do not have any project in mind to do, so I will just experiment with it until an idea comes.
Do you think I should buy it or just stick with some cheap development platform like Nucleo and don't bother. I think Nucleo already has a build in debugger.
What I find very nice is that it doesn't matter what MCU you are using as long as it is an ARM M and you can program and debug it without the need of having individual programmers for each vendor.
For 60 pounds it is a little bit pricey, but if I am going to focus on this in my free time it may be worth it. What do you think ?
Regards,
Alin
One man's 'magic' is another man's engineering. 'Supernatural' is a null word. - Robert A. Heinlein
Online ataradov
    • Personal site
Re: Segger JLink - Worth it for hobby use ?
« Reply #1 on: August 21, 2017, 12:04:03 am »
It all depends on your style of work.
I personally would not get one for $10. But a lot of people think about then as "profesional" for some arbitrary reason.
Alex
Offline filssavi
« Reply #2 on: August 21, 2017, 12:40:02 am »
The biggest advantage as you mentioned is the cross vendor compatibility is very nice, but It is not the only advantage, often the ICE you find on cheap Dev board are somewhat slow (very slow some times) and they might have less features and more often than not they are just cut down j-link's
Offline evb149
« Reply #3 on: August 21, 2017, 12:41:40 am »
You might be able to get / use one of the newer less expensive ones.
https://www.segger.com/jlink-edu-mini.html
Whether it is beneficial depends on what devices you want to program and debug.
If your devices are well supported under your chosen OS / HW / IDE / SW tool platform by an IC vendor provided / oriented unit like for instance the ST Link or the XDS110 or whatever applies for your ICs then you're probably not missing much or anything by not using the Jlink.  In fact you may find situations where the alternative debugger / programmer units are BETTER supported and more functional in your IDE than the Jlink is which wouldn't be surprising if you're also using the IC vendor supplied / oriented IDE e.g. Code Composer or whatever.
On the other hand if you're using some generic tool chain like GCC + GDB + maybe stock eclipse then your choices are pretty wide as to debugger / programmer HW and you can just see what reportedly works well with your OS + MCU + environment.
The main alternatives for somewhat MCU family portable debugging / programming would be something that implements CMSIS-DAP or which something like OpenOCD talks to / supports well and there are not all that many universal solutions out there, though if you research what works with a particular MCU + OS environment you may find a couple alternatives.
Besides the "crippleware" limitations of the IDE or debugger driver you may run into with various IDE or debugger HW + driver options your main limitations and challenges will be:
* Pinout -- does the debugger's included or easily attained cable match your targets?  Is there any protection somewhere for "off by one" or "plugged in backwards" scenarios?
* Power supply / interface voltages -- does it work with your target's voltages?  What happens if the target is powered but the debugger HW is not and they are connected?  What happens if the debugger is powered and the target is not?  What happens if some wrong interface setting is applied to the debugger?
* Debug / programming protocol options: Do you want / need: cJTAG, JTAG, SWD, SWO support?
* What about means for the target to provide log output (and maybe input) from an additional virtual or real serial communications channel?  Sometimes that is supported in the targed debug interface pinout as HW signals like SWO or some other scheme..  Sometimes debugger signals and channels can carry that information like in the case of RTT.  Sometimes you have a LVTTL-UART interface and you may want your debugger to support that also as some of the KitProg / XDS110 / FT2232H / other style units do.
* Isolation -- would it be safer or more reliable for your target / debugger / PC if the debugger had some galvanic isolation between the PC / USB / ground voltages and the target?  If so then you better reconsider most of the low cost debugger boards as they will not likely have this.  Most probably have little if any protection for ESD, reverse polarity, overcurrent, or different logic interface voltages.
Personally I guess for the price I'd try to have "a couple of a few different low cost model options" around because sometimes the right tool for a particular job is a certain unit.  And you can never tell when you're in the middle of a project and your debugger may break at which point having an alternative around is pretty handy.
The following users thanked this post: alin_im
Offline Kjelt
« Reply #4 on: August 21, 2017, 12:52:28 am »
There is firmware to reprogram an stlink to segger jlink, you have to google it but for €20 for the st link that could be a better deal. However a genuine segger is always preferred IMO.
Offline stmdude
« Reply #5 on: August 21, 2017, 12:53:45 am »
Yea, I've had the misfortune of recently being introduced to the Segger J-Links (not the EDU version, the bigger ones).
The hardware seems alright, but their software is utter crap. At least the command-line stuff is, as I haven't tested their IDE integration..
Even if you disregard the softwares lack of documentation, idiotic arguments to the commands (which the debugger could have figured out itself), and other idiosyncrasies, there's very, very little value-add to a JLink compared to a $20 ST-Link, or even a $2 clone of a ST-Link.
Some people get hung up on Seggers "RTT" functionality, which on a powerpoint level looks great. Except, their software suck. As in, their logging-system _looses_ messages.  Hint: The SEGGER_RTT.c files have no atomic functions or locking in place.
Right now, I can only find two good things to say about the Seggers (when they work).
First one: The time it takes to flash is slightly shorter, as they read out the flash, compare and then only writes the changed pages to flash.
Second: Their RTOS integration in the GDBserver is actually pretty convenient.
Oh, and in case you don't already know, the ST-Links (as all SWD DAPs) will work just fine with other vendors chips. You can use it to flash NXP, Nordic, Atmel, etc, etc. As long as they are Cortex-M with an SWD port (or JTAG for that matter), it'll work.
I might have mentioned ST-Link more than a few times here, but that's just because they're very easy to get a hold of. Any other adapter will do the job as well, such as (for example) a CMSIS-DAP.
Offline NANDBlog
« Reply #6 on: August 21, 2017, 12:55:42 am »
I dont think so. First, you can buy about 5 STM Discovery, or the Nucleo boards for the same price. Or the boards that you like. I also find Jtag to be cumbersome for hobby projects, because of the connector. It is perfectly fine to have a 144 pin huge MCU with dedicated JTAG pins and 4 layer board routing everything nicely, but this is for hobby. The usual cheap demo boards will all have built in USB debug SWD or similar, and no JTAG interface. And that interface is enough for 95% of use cases.
Offline stmdude
« Reply #7 on: August 21, 2017, 12:56:07 am »
Well, it comes with a "few" reservations..
  • May be used with ARM based ST devices only
  • Only debugging on evaluation boards is allowed. Debugging on custom hardware is not supported and not allowed
  • No production flash programming support
  • Unlimited breakpoints in flash available for evaluation only
  • No support is given
The following users thanked this post: Kjelt
Offline alin_im
« Reply #8 on: August 21, 2017, 01:16:45 am »
Thank you for the replies, what I have concluded for now is that the best solution is to wait and see what I will need when I will need it.
One last thing, do you think that the eBay clones are worth it (8 pounds instead of 60) or there are garbage ?
Alin
Offline evb149
« Reply #9 on: August 21, 2017, 01:40:51 am »
I'd get the 15 Euro real JLINK mini from Segger unless the 60$ version was really better for my needs somehow(?).
Or a real STLINK if applicable.
I would not touch an ebay clone.
The only good ebay / generic ones could in my opinion be something that is a "clone" of something that is based on a fully open hardware specification / schematic / firmware anyway, and that's probably the case for several debuggers like the TI XDS100/XDS110 or Cypress KitProg  for instance I think all the schematics / firmware codes for the programming units are openly available for people to make their own debuggers or targets with integrated programming.  So in such cases there is less to worry about getting something from eBay or whatever as long as credible people independent of the vendor have verified that the product is really "just" the usual open HW device built from the open schematics with non counterfeit parts.
Alin
Offline alin_im
« Reply #10 on: August 21, 2017, 02:32:38 am »
I do not see myself working with CPUs higher than M4 so I think that the JLINK mini is a much better choice. Do you know if it accepts it up to M4 ?
« Last Edit: August 21, 2017, 02:41:01 am by alin_im »
Offline hans
« Reply #11 on: August 21, 2017, 04:43:15 am »
J-LINK EDU Mini is a version of the J-Link EDU in a reduced form factor with identical functionality for Cortex-M based targets.  It has been designed to allow students and educational facilities as well as hobbyists access to top of the line debug probe technology.
I.e. they dropped the 20-pin boxed JTAG header and went for the 10-pin Cortex-M debug only. That is fine for regular SWD usage, no need for trace, etc. It also drops support for some of the older ARM7TDMI cores, which some need the RTCK signal (I think LPC2100 does, not familiar with others). But if you only plan to use modern parts with Cortex m0+ and up, that's not a problem. Actually, I think it's a wicked deal considering it's a tiny debugger for a much better price.
I would probably pick one up along a ST discovery board (or any other brand) anyway. Because with a vendor dev board you're locked in to them, and that's usually bad long term.
For 20$ I wouldn't touch any Ebay knock off. Not worth it.
Offline alin_im
« Reply #12 on: August 21, 2017, 05:43:29 am »
Just realized I have a Silicon Zero Gecko https://www.silabs.com/products/development-tools/mcu/32-bit/efm32-zero-gecko-starter-kit dev kit and in its specs says that contains Integrated SEGGER J-Link USB debugger/emulator with debug out functionality  does this means that the 60 pounds device is already integrated into a 30 pounds platform ?
Maybe you can clarify this for me, is this like the STLink which can program only S Labs MCUs ? Or can accept any vendor MCU ?  :-// :-//
Offline thm_w
« Reply #13 on: August 22, 2017, 09:25:23 am »
The cost is for the software not the hardware, the hardware is ~$2 of parts. If you care a lot about cost you can look at the mini EDU model already suggested, which is about $20.
I suspect its limited, to test yourself: plug in your dev board, run J-Flash, choose a non-EFM32 part, and select target->connect. It will give you an error message if they've restricted access (most likely did).
Offline hans
« Reply #14 on: August 22, 2017, 06:21:08 pm »
Yes, on the Giant gecko board I have the J-link debugger circuitry is hidden under the LCD. They have hidden it because I suspect they use a ST part for it  :popcorn:
The functionality is quite extensive in that you can redirect the SWD offboard (but also turn the debugger off and use your own). However I haven't tried hooking it up to any non-Silicon Micro parts.
Offline mac.6
« Reply #15 on: August 22, 2017, 07:16:36 pm »
Lot of dev boards include debugger that can be flashed as a JLink debugger, most Kinetis parts are like this for example.
It's not an exact EDU version as most are very slow (around 4/8MHz) so advanced debug is limited (like RTT or SystemView usage).
RTT is a fine software, of course you need to provide some support for lock/unlock functions, it is far above uart and doesn't requires swo support. Only their linux support is lacking for the tools.
The following users thanked this post: hans
Offline alin_im
« Reply #16 on: August 22, 2017, 08:04:19 pm »
Thank you for all your responses, I will try the Jlink EDU mini because it super affordable and I will not see myself using more advanced MCUs then the ones with M4F, meaning that the Jlink EDU is too advanced for my purposes. Also, I think that 4 MHz is enough for my learning purposes, I do not intend to become an ARM guru, but to experiment and have an idea that is beyond using Mbed environment.
Offline Sal Ammoniac
« Reply #17 on: August 23, 2017, 04:00:22 am »
Several MCU manufacturers have licensed J-Link firmware from Segger and include it on their own debuggers. Some examples: the NXP LPC-Link 2 and the Infineon XMC Link.
Most of these are better values than a Segger J-Link, and/or include features the J-Link doesn't. For example, an LPC-Link 2 is only $20, and the XMC Link is isolated, which is a $250 add-on board for a Segger J-Link.
Never trust a government that doesn't trust you.
Offline plazma
    • Homepage
« Reply #18 on: August 23, 2017, 04:37:53 am »
You can also direct printf() to the SWO pin. At least with EFM32 chips.
Offline ElektroQuark
    • ElektroQuark
« Reply #19 on: August 23, 2017, 04:41:12 am »
Ozone is the debugger from SEGGER.
Look at it, you can use it with a J-LINK.
Offline andyturk
« Reply #20 on: August 23, 2017, 04:55:14 am »
This.
J-Link is worth it because you get to use Ozone. Technically, you're supposed to use one of Segger's hardware dongles with a "license" on it, but Ozone works just fine without that. You just have to acknowledge a dialog when you run it for the first time.
Using the J-Link on-board firmware, you can reflash the debug side of a STM32 disco board to be a J-Link and then debug it with Ozone. For under $20 USD it's a really sweet setup. Grab GCC 6.x from ARM (for free), your favorite text editor and you're good to go.
« Reply #21 on: August 23, 2017, 11:45:39 am »
What does Ozone do that Segger Embedded Studio doesn't?
Offline andyturk
« Reply #22 on: August 23, 2017, 12:43:46 pm »
Puts $1800 more dollars in your pocket?
For debugging, Ozone and SES are probably pretty close. I know folks who use SES and like it a lot. For me, I prefer to use emacs for editing and use gmake for builds, so all I need is a debugger. Ozone fits that bill nicely.
    • ElektroQuark
« Reply #23 on: August 23, 2017, 04:36:43 pm »
I'm using CodeBlocks as IDE with Ozone for debugging. Nice combo.
Offline ulix
« Reply #24 on: August 23, 2017, 07:20:18 pm »
Problem: the Jlink EDU is for education purpose only as well...
