Author Topic: Confusion with selecting the right load capacitor for crystal  (Read 1336 times)
Offline sangarTopic starter
  • Country: in
« on: September 09, 2017, 03:06:04 pm »
Hello all,
I am confused with selecting External load capacitor for Crystal(ABM3B-8.000MHZ-10-1-U-T )which have load capacitance of 10pF.Right now, I have used 10pF as external load capacitors in My circuit.But, Atmel says that to use the following formula to calculate external load capacitor..
CLEXT = 2(CL – CSTRAY – CSHUNT)
Where :
   CL =10pF= Crystal Load capacitance. The value of CL can be found in crystal datasheet
   CSTRAY = Parasitic Capacitance of the crystal pins ( XIN, XOUT) and PCB
   CSHUNT =3 to 7pF= Shunt capacitance of the crystal
CSTRAY = [(CXIN * CXOUT) / (CXIN + CXOUT)] + CPCB
As per SAM L21 device datasheet,  CXIN = 5.8pF, CXOUT = 3.2pF
Parasitic Capacitance (CPCB) of PCB is 0.5pF
External capacitor value after formula:
CSTRAY = [(5.9pF * 3.2pF) / (5.9pF + 3.2pF)] + 0.5pF = 2.5pF
CLEXT = 2(10pF – 2.5pF - 7pF) = 1pF
So, Should I change My external load capacitor from 10pF to 1pF?
Please suggest..
Thanks,
Sangar
« Last Edit: September 09, 2017, 03:25:26 pm by sangar »
Offline madires
  • A qualified hobbyist ;)
Re: Confusion with selecting the right load capacitor for crystal
« Reply #1 on: September 09, 2017, 03:50:31 pm »
If the crystal oscillates fine with 10pF then keep the 10pF caps. For time critical stuff replace one cap with a trimmer cap for adjusting the frequency. From my experience the ATmega's oscillator runs fine with 18-22pF load caps.
Offline Kleinstein
« Reply #2 on: September 09, 2017, 03:58:39 pm »
The C_shunt that is internal to the crystal might very well be already considered for the load. The only part to consider would than be C_shunt that is external to the crystal. Otherwise it would be odd to specify 10 pF load capacitance if 3-7 pF of this are already inside.
