I've begun working with an atmega328, unsuccessfully. I've been unable to get the IDE to communicate with it so I'm unable to get any of my sketches to upload.
Through the process of debugging why this could be, I began testing my serial cable. I have a USB -> TTL cable powered by a PL2303HX. If I loop the TX->RX pins together I can get output on a serial console so in general it appears to be working.
I disconnected the loopback in order to test the cable on a scope.
When I scoped out the TX line. It appeared like the signal was dropping when I entered characters into the serial console, which is what I'd expect.
When I then scoped out the RX line, I was getting a reverse effect, the signal appeared to spike on every key press.
Does anyone with serial experience know if this is normal, or is it likely I have a faulty cable?
