Author Topic: Is 18F46K80 supported by Pickit3?  (Read 2848 times)
Offline txescientistTopic starter
  • Country: cs
« on: December 15, 2016, 01:48:34 am »
I have searched but could't find the list of supported PICs by Pickit 3. Is 18F46K80 supported? I have Pickit 2 and it is not.
All the best, Milos.
Offline DTJ
Re: Is 18F46K80 supported by Pickit3?
« Reply #1 on: December 15, 2016, 01:56:55 am »
I just checked and the 18F46k80 appears in the selection list using MPLABX v3.35 + pickit3
The following users thanked this post: txescientist
  • Country: cs
« Reply #2 on: December 15, 2016, 02:04:45 am »
Thank you very much for the fast reply and good news  :-+. Just installed MPLABX, but I still can't see list of supported devices because I don't have Pickit 3 yet.
Online JPortici
« Reply #3 on: December 15, 2016, 06:11:51 am »
of course it is! i believe that the PK3 supports all the pics
btw, you should have a supported device list in the release notes for the IDE... and if you attempt to create a new project you will see the support state when you select the programming tool/compiler
Offline Bruce Abbott
    • Bruce Abbott's R/C Models and Electronics
« Reply #4 on: December 15, 2016, 06:19:00 am »
Update your PICkit2 device file, and then it will be!
https://github.com/GBert/misc/tree/master/pickit2/pk2dft
  • Country: cs
« Reply #5 on: December 15, 2016, 10:35:51 am »
Thank you all, especially Bruce for help. I am really glad that I can still use my good old Pickit 2  :-+
