I don't recall the exact type but it was a battery charge gauge chip from TI.
Wonder if it's actually a preprogrammed MCU, which would explain the need for stretching - I recently fond that the Atmel AT42QT1070 capsense chip is just a preprogrammed ATTinysomething - first time I'd ever seen anything use clock stretching.
Most I2C/SPI GPIO extenders from Microchip are programmed micros. Also, I suspect the USB-UART and other converters are just preprogrammed and marked PICs. But I suspect other manufacturers are doing the same. Maybe not to the extent, where you can reprogram it.
