The design flow is identical to normal FPGAs - the tools are identical because the space grade and non-space grade FPGAs have the same functionality, they just have different silicon. The space grade parts are certified to be able to stand a certain TID (level of radiation), that is the only difference.
But, this doesn't mean that companies developing for space grade FPGAs will use the same design flow, they will often have similar flows to safety critical designs - where the design is tested to a higher degree, with the tools providing assurance that the design is not modified during layout and routing.
This does mean that you can spend time developing for space, but targeting commercial grade FPGAs, which is a lot cheaper until very late in the product design.
There are some additional steps if you use certain FPGA features - I have a colleague who is using partial reconfiguration in Virtex FPGAs to allow for partial recovery of a design when an error is detected, which requires a certain type of bit file.
TMR repeats the logic three times and adds some voting logic, so if you use TMR on all of your design, it will take up 3x the logic cells, plus a little bit. A large downside to this is that it can significantly impact the timing.
Why would there be a restriction on different resources?
What are you planning to build? Are you jumping in the deep end with trying to target space - a lot of companies would be more impressed with well designed non-space projects than a poorly made space project.
