Need an oven controlled oscillator for that kind of precision, too. Take a close look at the jitter specs of your room temperature crystals that's your precision. Now take a look at temperature coefficients and time coefficients, there's your accuracy.
Having precision down to 1 ppb with a precision/accuracy of 20ppm doesn't make sense.
If the OP, doesn't need this level of precision, then the OP should consider relaxing the resolution requirement. If he needs accuracy and precision implied by his resolution, then the answers provided will only lead the OP to frustration.
Either way, everyone is jumping to provide solutions without defining the requirements.
Anyway, carry on.
