And also, ST has free toolchain. It is called "System Workbench for STM32" (www.openstm32.org). But never have tried that. Is it worth a try?
it's not an official ST toolchain, it's an other eclipce based IDE.
i tried it for a short time only to go back to IAR, so many problem some of them you end up heating you head into the wall, with not so good community support, starting with compatibility with st-link and that under-reset crap error , slow flashing and debugging ( few second more that IAR ), unpractical for debug ,you have to perform 4 to 5 mouse clic to enter or exit debug mode , NO RESET BUTTON ON DEBUG INTERFACE , i have to restart it all from the beginning, the target will stop running when exit debug mode , and so on.
The nice thing though is that it support standard peripheral library , so you can use same file you wrote with IAR under OpenSTM32 with no trouble, just put them on the workspace and you can compile them quite easily.
As i didn't use any NXP , can't help on this side, but for ST their uC are pretty awesome, but check erreta first. and avoid using HAL library ... the one who invented that HAL crap deserve a place in hell, standard peripheral library is much readable and easier to follow.
