My experience is the complete opposite. I need to use "google" as my primary support tool for Keil as well, and chances are I have more search results for GNU tools than for Keil or IAR.
We used to work with IAR at work, but switched to Keil. I needed to compile (several firmware builds we want to try in the field) and download (released bootloader image) a few SREC images for a few test units. Couldn't find the "Download SREC" and "Compile to SREC" button in Keil. Was thoroughly disappointed.
I have setup my hobby toolchain now with Qt Creator + GCC/GDB + OpenOCD. It has full debugging support, I can write batch scripts for anything I need (like production programming of any file), and IMHO most importantly I wrote my QBS project file in such a way that I can seamlessly switch between x86 device and an ARM device. Once the hardware is fully abstracted or mocked it's pretty darn easy to test program logic & protocols on a desktop machine. And that with the click of 1 button, staying in the exact same IDE & file views, etc.
As for the OP's question: I agree that NXP products seem very mature and robust, IMHO more tailored towards that than the absolute lowest price or highest banner specs. ST seem more feature rich, but consider the front-page just as a brochure (good general tip for any datasheet anyway). Sometimes some combinations are not possible on the ST devices, like I was a bit disappointed in how DMA works on STM32F4 compared to the PIC's or AVR's (which is much simpler to setup). STM32Cube is a nice program however to lay out peripheral pinning on the bigger chips, where finding a path through 6 SPI's, 5 I2C's, 8 UARTS, SDRAM, LCD, Ethernet and 3 ADC's is quite dizzying.
I think both boards (LPCxpresso vs ST Link) have pretty similar debuggers, which only work for NXP/ST brands. Watch out for the older LPCxpresso boards though, they only work with CodeRed's IDE (which also has code size limits I believe).
